Datasheet Intersil X9118 — Даташит
Производитель | Intersil |
Серия | X9118 |
Двойное питание/низкое энергопотребление/1024 отвода/2-проводная шина Одиночный потенциометр с цифровым управлением (XDCP)
![]() 14 предложений от 14 поставщиков Микросхема Цифровой потенциометр , Digital Potentiometer 1024POS 100KΩ Single 14Pin TSSOP | |||
X9118TV14-2.7 Renesas | по запросу | ||
X9118TV14 Intersil | по запросу | ||
X9118TV14 | X9118TV14-2.7 | X9118TV14I | X9118TV14I-2.7 | X9118TV14IZ | X9118TV14IZ-2.7 | X9118TV14Z | X9118TV14Z-2.7 | |
N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 |
Корпус | 14 Ld TSSOP | 14 Ld TSSOP | 14 Ld TSSOP | 14 Ld TSSOP | 14 Ld TSSOP | 14 Ld TSSOP | 14 Ld TSSOP | 14 Ld TSSOP |
Parameters / Models | X9118TV14 | X9118TV14-2.7 | X9118TV14I | X9118TV14I-2.7 | X9118TV14IZ | X9118TV14IZ-2.7 | X9118TV14Z | X9118TV14Z-2.7 |
# of Taps | 1024 | 1024 | 1024 | 1024 | 1024 | 1024 | 1024 | 1024 |
Количество каналов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Description | Dual Supply/Low Power/1024-Tap/2-Wire Bus Single Digitally-Controlled (XDCP?) Potentiometer | Dual Supply/Low Power/1024-Tap/2-Wire Bus Single Digitally-Controlled (XDCP?) Potentiometer | Dual Supply/Low Power/1024-Tap/2-Wire Bus Single Digitally-Controlled (XDCP?) Potentiometer | Dual Supply/Low Power/1024-Tap/2-Wire Bus Single Digitally-Controlled (XDCP?) Potentiometer | Dual Supply/Low Power/1024-Tap/2-Wire Bus Single Digitally-Controlled (XDCP?) Potentiometer | Dual Supply/Low Power/1024-Tap/2-Wire Bus Single Digitally-Controlled (XDCP?) Potentiometer | Dual Supply/Low Power/1024-Tap/2-Wire Bus Single Digitally-Controlled (XDCP?) Potentiometer | Dual Supply/Low Power/1024-Tap/2-Wire Bus Single Digitally-Controlled (XDCP?) Potentiometer |
Dual Supply Range (V) | -2.7 to -5.5, +2.7 to +5.5 | -2.7 to -5.5, +2.7 to +5.5 | -2.7 to -5.5, +2.7 to +5.5 | -2.7 to -5.5, +2.7 to +5.5 | -2.7 to -5.5, +2.7 to +5.5 | -2.7 to -5.5, +2.7 to +5.5 | -2.7 to -5.5, +2.7 to +5.5 | -2.7 to -5.5, +2.7 to +5.5 |
End-to-End Tempco (В±ppm/В°C) | 300 | 300 | 300 | 300 | 300 | 300 | 300 | 300 |
ICC | 3 μA | 3 μA | 3 μA | 3 μA | 3 μA | 3 μA | 3 μA | 3 μA |
Interface Type | 2-Wire | 2-Wire | 2-Wire | 2-Wire | 2-Wire | 2-Wire | 2-Wire | 2-Wire |
Max Operating Temp | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C |
Memory Type | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile |
Middlepoint Ratiometric Tempco | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Peak Temp | 240°C | 240°C | 240°C | 240°C | 260°C | 260°C | 260°C | 260°C |
Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
Resistance Options (kΩ) | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 |
Resistance Options (kО©) | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 |
Resistance Taper | Linear | Linear | Linear | Linear | Linear | Linear | Linear | Linear |
VCC (max) | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
VCC (min) | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V |
VL Max. Terminal Voltage | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
VL Min. Terminal Voltage | -5.5 V | -5.5 V | -5.5 V | -5.5 V | -5.5 V | -5.5 V | -5.5 V | -5.5 V |
Wiper Current | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA |
Wiper Resistance | 40 О© | 40 О© | 40 О© | 40 О© | 40 О© | 40 О© | 40 О© | 40 О© |
Интерфейс | 2-Wire | 2-Wire | 2-Wire | 2-Wire | 2-Wire | 2-Wire | 2-Wire | 2-Wire |
RoHS | Совместим | Совместим | Совместим | Совместим |
Серия: X9118 (8)
- Data Converters > Digital Potentiometers (DCPs) > DCPs
