Линейка продуктов KEEN SIDE
Datasheet Intersil X9252 — Даташит
ПроизводительIntersil
СерияX9252
Счетверенный потенциометр с цифровым управлением (XDCP)
X9252 Datasheet
PDF, 813 Кб, Версия: 01-11-2017
13 предложений от 12 поставщиков
X9252YVZG
X9252TV24-2.7
Renesas
X9252UV24-2.7
Intersil
Hi-Tech Circuit Group
X9252TV24-2.7
X9252TS24I-2.7X9252TS24IZ-2.7X9252TV24I-2.7X9252TV24IZ-2.7X9252US24I-2.7X9252US24IZ-2.7X9252UV24I-2.7X9252UV24IZ-2.7X9252WS24I-2.7X9252WS24IZ-2.7X9252WV24I-2.7X9252WV24IZ-2.7X9252YV24I-2.7X9252YV24IZ-2.7
N1234567891011121314
Корпус24 Ld SOIC24 Ld SOIC24 Ld TSSOP24 Ld TSSOP24 Ld SOIC24 Ld SOIC24 Ld TSSOP24 Ld TSSOP24 Ld SOIC24 Ld SOIC24 Ld TSSOP24 Ld TSSOP24 Ld TSSOP24 Ld TSSOP
Parameters / ModelsX9252TS24I-2.7X9252TS24IZ-2.7X9252TV24I-2.7X9252TV24IZ-2.7X9252US24I-2.7X9252US24IZ-2.7X9252UV24I-2.7X9252UV24IZ-2.7X9252WS24I-2.7X9252WS24IZ-2.7X9252WV24I-2.7X9252WV24IZ-2.7X9252YV24I-2.7X9252YV24IZ-2.7
# of Taps256256256256256256256256256256256256256256
Количество каналов44444444444444
DescriptionQuad Digitally-Controlled (XDCP?) PotentiometerQuad Digitally-Controlled (XDCP?) PotentiometerQuad Digitally-Controlled (XDCP?) PotentiometerQuad Digitally-Controlled (XDCP?) PotentiometerQuad Digitally-Controlled (XDCP?) PotentiometerQuad Digitally-Controlled (XDCP?) PotentiometerQuad Digitally-Controlled (XDCP?) PotentiometerQuad Digitally-Controlled (XDCP?) PotentiometerQuad Digitally-Controlled (XDCP?) PotentiometerQuad Digitally-Controlled (XDCP?) PotentiometerQuad Digitally-Controlled (XDCP?) PotentiometerQuad Digitally-Controlled (XDCP?) PotentiometerQuad Digitally-Controlled (XDCP?) PotentiometerQuad Digitally-Controlled (XDCP?) Potentiometer
Dual Supply Range (V)N/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/A
End-to-End Tempco (В±ppm/В°C)300300300300300300300300300300300300300300
Основные особенностиInterface configured to allow I2C to function like U/DInterface configured to allow I2C to function like U/DInterface configured to allow I2C to function like U/DInterface configured to allow I2C to function like U/DInterface configured to allow I2C to function like U/DInterface configured to allow I2C to function like U/DInterface configured to allow I2C to function like U/DInterface configured to allow I2C to function like U/DInterface configured to allow I2C to function like U/DInterface configured to allow I2C to function like U/DInterface configured to allow I2C to function like U/DInterface configured to allow I2C to function like U/DInterface configured to allow I2C to function like U/DInterface configured to allow I2C to function like U/D
ICC100 μA100 μA100 μA100 μA100 μA100 μA100 μA100 μA100 μA100 μA100 μA100 μA100 μA100 μA
Interface Type2-Wire, 3-Wire (Up/Down)2-Wire, 3-Wire (Up/Down)2-Wire, 3-Wire (Up/Down)2-Wire, 3-Wire (Up/Down)2-Wire, 3-Wire (Up/Down)2-Wire, 3-Wire (Up/Down)2-Wire, 3-Wire (Up/Down)2-Wire, 3-Wire (Up/Down)2-Wire, 3-Wire (Up/Down)2-Wire, 3-Wire (Up/Down)2-Wire, 3-Wire (Up/Down)2-Wire, 3-Wire (Up/Down)2-Wire, 3-Wire (Up/Down)2-Wire, 3-Wire (Up/Down)
Max Operating Temp85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C
Memory TypeNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatile
Middlepoint Ratiometric Tempco2020202020202020202020202020
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Peak Temp240°C260°C240°C260°C240°C260°C240°C260°C240°C260°C240°C260°C240°C260°C
Qualification LevelStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandard
Resistance Options (kΩ)2, 102, 102, 102, 102, 102, 102, 102, 102, 102, 102, 102, 102, 102, 10
Resistance Options (kО©)2, 102, 102, 102, 102, 102, 102, 102, 102, 102, 102, 102, 102, 102, 10
Resistance TaperLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinear
VCC (max)5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V
VCC (min)2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V
VL Max. Terminal Voltage5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V
VL Min. Terminal Voltage0 V0 V0 V0 V0 V0 V0 V0 V0 V0 V0 V0 V0 V0 V
Wiper Current3 mA3 mA3 mA3 mA3 mA3 mA3 mA3 mA3 mA3 mA3 mA3 mA3 mA3 mA
Wiper Resistance50 О©50 О©50 О©50 О©50 О©50 О©50 О©50 О©50 О©50 О©50 О©50 О©50 О©50 О©
Интерфейс2-Wire, 3-Wire (Up/Down)2-Wire, 3-Wire (Up/Down)2-Wire, 3-Wire (Up/Down)2-Wire, 3-Wire (Up/Down)2-Wire, 3-Wire (Up/Down)2-Wire, 3-Wire (Up/Down)2-Wire, 3-Wire (Up/Down)2-Wire, 3-Wire (Up/Down)2-Wire, 3-Wire (Up/Down)2-Wire, 3-Wire (Up/Down)2-Wire, 3-Wire (Up/Down)2-Wire, 3-Wire (Up/Down)2-Wire, 3-Wire (Up/Down)2-Wire, 3-Wire (Up/Down)
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместим
  • Data Converters > Digital Potentiometers (DCPs) > DCPs
На английском языке: Datasheet Intersil X9252
