Datasheet Intersil X9C303V8IT5 — Даташит
ПроизводительIntersil
СерияX9C303
МодельX9C303V8IT5
Logarithmic Digitally Controlled Potentiometer (XDCP), Terminal Voltage В±5V, 100 Taps, Log Taper
X9C303 Datasheet
PDF, 542 Кб, Версия: 31-10-2017
X9C303V8IT5
Intersil
Корпус8 Ld TSSOP T+R
# of Taps100
Количество каналов1
DescriptionLogarithmic Digitally Controlled Potentiometer (XDCP?), Terminal Voltage ?5V, 100 Taps, Log Taper
Dual Supply Range (V)N/A
End-to-End Tempco (В±ppm/В°C)400
Основные особенностиIntegrated charge pump to allow for single supply to swing -5.5V to 5.5V
ICC200 μA
Interface Type3-Wire (Up/Down)
Max Operating Temp85 °C
Memory TypeNonvolatile
Middlepoint Ratiometric Tempco20
Количество каналов1
Peak Temp240°C
Qualification LevelStandard
Resistance Options (kΩ)32
Resistance Options (kО©)32
Resistance TaperLogarithmic
VCC (max)5.5 V
VCC (min)4.5 V
VL Max. Terminal Voltage5 V
VL Min. Terminal Voltage-5 V
Wiper Current1 mA
Wiper Resistance40 О©
Интерфейс3-Wire (Up/Down)
  • Data Converters > Digital Potentiometers (DCPs) > DCPs
На английском языке: Datasheet Intersil X9C303V8IT5
