Datasheet Intersil ISL22346 — Даташит
Производитель | Intersil |
Серия | ISL22346 |
Четырехпотенциометры с цифровым управлением (XDCP); Малошумная, маломощная шина I 2 C, 128 ответвлений
![]() 10 предложений от 10 поставщиков , Digital Potentiometer, 1 Func, 10000ohm, 2-wire Serial Control Interface, 128 Positions, PDSO20 | |||
ISL22346WMVEP Renesas | 73 ₽ | ||
ISL22346WMVEP-TK | по запросу | ||
ISL22346WFZ Intersil | по запросу |
ISL22346UFRT20Z | ISL22346UFRT20Z-TK | ISL22346UFV20Z | ISL22346UFV20Z-TK | ISL22346WFRT20Z | ISL22346WFRT20Z-TK | ISL22346WFV20Z | ISL22346WFV20Z-TK | |
N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 |
Корпус | 20 Ld TQFN | 20 Ld TQFN T+R | 20 Ld TSSOP | 20 Ld TSSOP T+R | 20 Ld TQFN | 20 Ld TQFN T+R | 20 Ld TSSOP | 20 Ld TSSOP T+R |
Parameters / Models | ISL22346UFRT20Z | ISL22346UFRT20Z-TK | ISL22346UFV20Z | ISL22346UFV20Z-TK | ISL22346WFRT20Z | ISL22346WFRT20Z-TK | ISL22346WFV20Z | ISL22346WFV20Z-TK |
# of Taps | 128 | 128 | 128 | 128 | 128 | 128 | 128 | 128 |
Количество каналов | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 |
Description | Quad Digitally Controlled Potentiometers (XDCP?); Low Noise, Low Power I2C? Bus, 128 Taps | Quad Digitally Controlled Potentiometers (XDCP?); Low Noise, Low Power I2C? Bus, 128 Taps | Quad Digitally Controlled Potentiometers (XDCP?); Low Noise, Low Power I2C? Bus, 128 Taps | Quad Digitally Controlled Potentiometers (XDCP?); Low Noise, Low Power I2C? Bus, 128 Taps | Quad Digitally Controlled Potentiometers (XDCP?); Low Noise, Low Power I2C? Bus, 128 Taps | Quad Digitally Controlled Potentiometers (XDCP?); Low Noise, Low Power I2C? Bus, 128 Taps | Quad Digitally Controlled Potentiometers (XDCP?); Low Noise, Low Power I2C? Bus, 128 Taps | Quad Digitally Controlled Potentiometers (XDCP?); Low Noise, Low Power I2C? Bus, 128 Taps |
Dual Supply Range (V) | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A |
End-to-End Tempco (В±ppm/В°C) | 50 | 50 | 50 | 50 | 50 | 50 | 50 | 50 |
Основные особенности | 3 terminal DCP with shutdown feature | 3 terminal DCP with shutdown feature | 3 terminal DCP with shutdown feature | 3 terminal DCP with shutdown feature | 3 terminal DCP with shutdown feature | 3 terminal DCP with shutdown feature | 3 terminal DCP with shutdown feature | 3 terminal DCP with shutdown feature |
ICC | 5 μA | 5 μA | 5 μA | 5 μA | 5 μA | 5 μA | 5 μA | 5 μA |
Interface Type | I2C | I2C | I2C | I2C | I2C | I2C | I2C | I2C |
Max Operating Temp | 125 °C | 125 °C | 125 °C | 125 °C | 125 °C | 125 °C | 125 °C | 125 °C |
Memory Type | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile |
Middlepoint Ratiometric Tempco | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 |
Рабочий диапазон температур | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 |
Peak Temp | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C |
Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
Resistance Options (kΩ) | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 |
Resistance Options (kО©) | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 |
Resistance Taper | Linear | Linear | Linear | Linear | Linear | Linear | Linear | Linear |
VCC (max) | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
VCC (min) | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V |
VL Max. Terminal Voltage | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
VL Min. Terminal Voltage | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V |
Wiper Current | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA |
Wiper Resistance | 70 О© | 70 О© | 70 О© | 70 О© | 70 О© | 70 О© | 70 О© | 70 О© |
Интерфейс | I2C | I2C | I2C | I2C | I2C | I2C | I2C | I2C |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: ISL22346 (8)
- Data Converters > Digital Potentiometers (DCPs) > DCPs
