Datasheet Intersil ISL22424 — Даташит
ПроизводительIntersil
СерияISL22424
Dual Digitally Controlled Potentiometer (XDCP), Low Noise, Low Power, SPIВ® Bus, 256 Taps
ISL22424 Datasheet
PDF, 1.2 Мб, Версия: 18-10-2017
ИС, цифровые потенциометры 256 TAP FL RNG IND DL SPI DCP 14LD
TradeElectronics
ISL22424
Intersil
ISL22424TFR16ZISL22424TFR16Z-TKISL22424TFV14ZISL22424TFV14Z-TKISL22424UFR16ZISL22424UFR16Z-TKISL22424UFV14ZISL22424UFV14Z-TKISL22424WFR16ZISL22424WFR16Z-TKISL22424WFV14ZISL22424WFV14Z-TK
N123456789101112
Корпус16 Ld QFN16 Ld QFN T+R14 Ld TSSOP14 Ld TSSOP T+R16 Ld QFN16 Ld QFN T+R14 Ld TSSOP14 Ld TSSOP T+R16 Ld QFN16 Ld QFN T+R14 Ld TSSOP14 Ld TSSOP T+R
Parameters / ModelsISL22424TFR16ZISL22424TFR16Z-TKISL22424TFV14ZISL22424TFV14Z-TKISL22424UFR16ZISL22424UFR16Z-TKISL22424UFV14ZISL22424UFV14Z-TKISL22424WFR16ZISL22424WFR16Z-TKISL22424WFV14ZISL22424WFV14Z-TK
# of Taps256256256256256256256256256256256256
Количество каналов222222222222
DescriptionDual Digitally Controlled Potentiometer (XDCP?), Low Noise, Low Power, SPI? Bus, 256 TapsDual Digitally Controlled Potentiometer (XDCP?), Low Noise, Low Power, SPI? Bus, 256 TapsDual Digitally Controlled Potentiometer (XDCP?), Low Noise, Low Power, SPI? Bus, 256 TapsDual Digitally Controlled Potentiometer (XDCP?), Low Noise, Low Power, SPI? Bus, 256 TapsDual Digitally Controlled Potentiometer (XDCP?), Low Noise, Low Power, SPI? Bus, 256 TapsDual Digitally Controlled Potentiometer (XDCP?), Low Noise, Low Power, SPI? Bus, 256 TapsDual Digitally Controlled Potentiometer (XDCP?), Low Noise, Low Power, SPI? Bus, 256 TapsDual Digitally Controlled Potentiometer (XDCP?), Low Noise, Low Power, SPI? Bus, 256 TapsDual Digitally Controlled Potentiometer (XDCP?), Low Noise, Low Power, SPI? Bus, 256 TapsDual Digitally Controlled Potentiometer (XDCP?), Low Noise, Low Power, SPI? Bus, 256 TapsDual Digitally Controlled Potentiometer (XDCP?), Low Noise, Low Power, SPI? Bus, 256 TapsDual Digitally Controlled Potentiometer (XDCP?), Low Noise, Low Power, SPI? Bus, 256 Taps
Dual Supply Range (V)-2.25 to -5.5-2.25 to -5.5-2.25 to -5.5-2.25 to -5.5-2.25 to -5.5-2.25 to -5.5-2.25 to -5.5-2.25 to -5.5-2.25 to -5.5-2.25 to -5.5-2.25 to -5.5-2.25 to -5.5
End-to-End Tempco (В±ppm/В°C)454545454545454545454545
Основные особенностиDaisy Chainable to minimize # I/0 pins on microcontroller, dual supply requiredDaisy Chainable to minimize # I/0 pins on microcontroller, dual supply requiredDaisy Chainable to minimize # I/0 pins on microcontroller, dual supply requiredDaisy Chainable to minimize # I/0 pins on microcontroller, dual supply requiredDaisy Chainable to minimize # I/0 pins on microcontroller, dual supply requiredDaisy Chainable to minimize # I/0 pins on microcontroller, dual supply requiredDaisy Chainable to minimize # I/0 pins on microcontroller, dual supply requiredDaisy Chainable to minimize # I/0 pins on microcontroller, dual supply requiredDaisy Chainable to minimize # I/0 pins on microcontroller, dual supply requiredDaisy Chainable to minimize # I/0 pins on microcontroller, dual supply requiredDaisy Chainable to minimize # I/0 pins on microcontroller, dual supply requiredDaisy Chainable to minimize # I/0 pins on microcontroller, dual supply required
ICC0.5 μA0.5 μA0.5 μA0.5 μA0.5 μA0.5 μA0.5 μA0.5 μA0.5 μA0.5 μA0.5 μA0.5 μA
Interface TypeSPISPISPISPISPISPISPISPISPISPISPISPI
Max Operating Temp125 °C125 °C125 °C125 °C125 °C125 °C125 °C125 °C125 °C125 °C125 °C125 °C
Memory TypeNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatile
Middlepoint Ratiometric Tempco444444444444
Рабочий диапазон температурот -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125
Peak Temp260°C260°C260°C260°C260°C260°C260°C260°C260°C260°C260°C260°C
Qualification LevelStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandard
Resistance Options (kΩ)101010101010101010101010
Resistance Options (kО©)101010101010101010101010
Resistance TaperLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinear
VCC (max)5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V
VCC (min)2.25 V2.25 V2.25 V2.25 V2.25 V2.25 V2.25 V2.25 V2.25 V2.25 V2.25 V2.25 V
VL Max. Terminal Voltage5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V
VL Min. Terminal Voltage-5.5 V-5.5 V-5.5 V-5.5 V-5.5 V-5.5 V-5.5 V-5.5 V-5.5 V-5.5 V-5.5 V-5.5 V
Wiper Current3 mA3 mA3 mA3 mA3 mA3 mA3 mA3 mA3 mA3 mA3 mA3 mA
Wiper Resistance70 О©70 О©70 О©70 О©70 О©70 О©70 О©70 О©70 О©70 О©70 О©70 О©
ИнтерфейсSPISPISPISPISPISPISPISPISPISPISPISPI
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
  • Data Converters > Digital Potentiometers (DCPs) > DCPs
На английском языке: Datasheet Intersil ISL22424
