Datasheet Intersil X9313WMI — Даташит
ПроизводительIntersil
СерияX9313
МодельX9313WMI
Digitally Controlled Potentiometer, Linear, 32 Taps, 3 Wire Interface, Terminal Voltages В± VCC
X9313 Datasheet
PDF, 588 Кб, Версия: 01-11-2017
IC XDCP 32-TAP 10K 3-WIRE 8-MSOP / Digital Potentiometer 10kOhm 32POS Non-Volatile Linear 8-Pin MSOP
X9313WMI
Intersil
X9313WMI-3T1C7886
Intersil
X9313WMI-3
Intersil
Hi-Tech Circuit Group
X9313WMI-3T1
Корпус8 Ld MSOP
# of Taps32
Количество каналов1
DescriptionDigitally Controlled Potentiometer, Linear, 32 Taps, 3 Wire Interface, Terminal Voltages ? VCC
Dual Supply Range (V)N/A
End-to-End Tempco (В±ppm/В°C)300
Основные особенностиIntegrated charge pump to allow for single supply to swing -5.5V to 5.5V
ICC200 μA
Interface Type3-Wire (Up/Down)
Max Operating Temp85 °C
Memory TypeNonvolatile
Middlepoint Ratiometric Tempco20
Количество каналов1
Peak Temp240°C
Qualification LevelStandard
Resistance Options (kΩ)1, 10, 50
Resistance Options (kО©)1, 10, 50
Resistance TaperLinear
VCC (max)5.5 V
VCC (min)3 V
VL Max. Terminal Voltage5.5 V
VL Min. Terminal Voltage-5.5 V
Wiper Current4.4 mA
Wiper Resistance40 О©
Интерфейс3-Wire (Up/Down)
  • Data Converters > Digital Potentiometers (DCPs) > DCPs
На английском языке: Datasheet Intersil X9313WMI
