Datasheet Intersil X95820 — Даташит
Производитель | Intersil |
Серия | X95820 |
Двойные цифровые потенциометры с управлением (XDCP); низкий уровень шума/низкое энергопотребление/2-проводная шина/256 точек переключения
6 предложений от 6 поставщиков Dual Digital Controlled Potentiometers | |||
X95820WV | по запросу | ||
X95820WV Xicor | по запросу | ||
X95820WVZG Intersil | по запросу | ||
X95820 Intersil | по запросу |
X95820UV14I-2.7 | X95820UV14I-2.7T1 | X95820UV14IZ-2.7 | X95820UV14IZ-2.7T1 | X95820WV14I-2.7 | X95820WV14I-2.7T1 | X95820WV14IZ-2.7 | X95820WV14IZ-2.7T1 | |
N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 |
Корпус | 14 Ld TSSOP | 14 Ld TSSOP T+R | 14 Ld TSSOP | 14 Ld TSSOP T+R | 14 Ld TSSOP | 14 Ld TSSOP T+R | 14 Ld TSSOP | 14 Ld TSSOP T+R |
Parameters / Models | X95820UV14I-2.7 | X95820UV14I-2.7T1 | X95820UV14IZ-2.7 | X95820UV14IZ-2.7T1 | X95820WV14I-2.7 | X95820WV14I-2.7T1 | X95820WV14IZ-2.7 | X95820WV14IZ-2.7T1 |
# of Taps | 256 | 256 | 256 | 256 | 256 | 256 | 256 | 256 |
Количество каналов | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Description | Dual Digital Controlled Potentiometers (XDCP?); Low Noise/Low Power/2-Wire Bus/256 Taps | Dual Digital Controlled Potentiometers (XDCP?); Low Noise/Low Power/2-Wire Bus/256 Taps | Dual Digital Controlled Potentiometers (XDCP?); Low Noise/Low Power/2-Wire Bus/256 Taps | Dual Digital Controlled Potentiometers (XDCP?); Low Noise/Low Power/2-Wire Bus/256 Taps | Dual Digital Controlled Potentiometers (XDCP?); Low Noise/Low Power/2-Wire Bus/256 Taps | Dual Digital Controlled Potentiometers (XDCP?); Low Noise/Low Power/2-Wire Bus/256 Taps | Dual Digital Controlled Potentiometers (XDCP?); Low Noise/Low Power/2-Wire Bus/256 Taps | Dual Digital Controlled Potentiometers (XDCP?); Low Noise/Low Power/2-Wire Bus/256 Taps |
Dual Supply Range (V) | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A |
End-to-End Tempco (В±ppm/В°C) | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 |
Основные особенности | Dual version of ISL95810 | Dual version of ISL95810 | Dual version of ISL95810 | Dual version of ISL95810 | Dual version of ISL95810 | Dual version of ISL95810 | Dual version of ISL95810 | Dual version of ISL95810 |
ICC | 5 μA | 5 μA | 5 μA | 5 μA | 5 μA | 5 μA | 5 μA | 5 μA |
Interface Type | I2C | I2C | I2C | I2C | I2C | I2C | I2C | I2C |
Max Operating Temp | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C |
Memory Type | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile |
Middlepoint Ratiometric Tempco | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Peak Temp | 240°C | 240°C | 260°C | 260°C | 240°C | 240°C | 260°C | 260°C |
Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
Resistance Options (kΩ) | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 |
Resistance Options (kО©) | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 |
Resistance Taper | Linear | Linear | Linear | Linear | Linear | Linear | Linear | Linear |
VCC (max) | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
VCC (min) | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V |
VL Max. Terminal Voltage | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
VL Min. Terminal Voltage | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V |
Wiper Current | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA |
Wiper Resistance | 70 О© | 70 О© | 70 О© | 70 О© | 70 О© | 70 О© | 70 О© | 70 О© |
Интерфейс | I2C | I2C | I2C | I2C | I2C | I2C | I2C | I2C |
RoHS | Совместим | Совместим | Совместим | Совместим |
Серия: X95820 (8)
- Data Converters > Digital Potentiometers (DCPs) > DCPs
