Компактное аудиорешение Nuvoton NSP2340BA24E
Datasheet Intersil X9318 — Даташит
ПроизводительIntersil
СерияX9318
Потенциометр с цифровым управлением (XDCP)
X9318 Datasheet
PDF, 477 Кб, Версия: 02-11-2017
X9318WP8X9318WP8IX9318WP8IZX9318WS8X9318WS8IX9318WS8IT1X9318WS8IZX9318WS8IZT1X9318WS8T1X9318WS8ZX9318WS8ZT1
N1234567891011
Корпус8 Ld PDIP8 Ld PDIP8 Ld PDIP8 Ld SOIC8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC T+R8 Ld SOIC8 Ld SOIC T+R
Parameters / ModelsX9318WP8X9318WP8IX9318WP8IZX9318WS8X9318WS8IX9318WS8IT1X9318WS8IZX9318WS8IZT1X9318WS8T1X9318WS8ZX9318WS8ZT1
# of Taps100100100100100100100100100100100
Количество каналов11111111111
DescriptionDigitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)
Dual Supply Range (V)N/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/A
End-to-End Tempco (В±ppm/В°C)300300300300300300300300300300300
Основные особенностиInternal charge pump to generate terminal voltage capability greater than VCCInternal charge pump to generate terminal voltage capability greater than VCCInternal charge pump to generate terminal voltage capability greater than VCCInternal charge pump to generate terminal voltage capability greater than VCCInternal charge pump to generate terminal voltage capability greater than VCCInternal charge pump to generate terminal voltage capability greater than VCCInternal charge pump to generate terminal voltage capability greater than VCCInternal charge pump to generate terminal voltage capability greater than VCCInternal charge pump to generate terminal voltage capability greater than VCCInternal charge pump to generate terminal voltage capability greater than VCCInternal charge pump to generate terminal voltage capability greater than VCC
ICC300 μA300 μA300 μA300 μA300 μA300 μA300 μA300 μA300 μA300 μA300 μA
Interface Type3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)
Max Operating Temp85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C
Memory TypeNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatile
Middlepoint Ratiometric Tempco2020202020202020202020
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Peak Temp240°C240°C240°C260°C260°C240°C260°C260°C
Qualification LevelStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandard
Resistance Options (kΩ)1010101010101010101010
Resistance Options (kО©)1010101010101010101010
Resistance TaperLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinear
VCC (max)5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V
VCC (min)4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V
VL Max. Terminal Voltage8 V8 V8 V8 V8 V8 V8 V8 V8 V8 V8 V
VL Min. Terminal Voltage0 V0 V0 V0 V0 V0 V0 V0 V0 V0 V0 V
Wiper Current3 mA3 mA3 mA3 mA3 mA3 mA3 mA3 mA3 mA3 mA3 mA
Wiper Resistance40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©
Интерфейс3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)
RoHSСовместимСовместимСовместимСовместимСовместим
  • Data Converters > Digital Potentiometers (DCPs) > DCPs
На английском языке: Datasheet Intersil X9318
Политика конфиденциальности
