Datasheet Intersil X9319 — Даташит
ПроизводительIntersil
СерияX9319
Потенциометр с цифровым управлением (XDCP)
X9319 Datasheet
PDF, 444 Кб, Версия: 02-11-2017
15 предложений от 15 поставщиков
Микросхема Цифро-аналоговый преобразователь, Digitally Controlled Potentiometer (XDCP)
X9319WS8
Renesas
LifeElectronics
X9319WP8
Intersil
SUV System
X9319UP8
X9319W
X9319UP8X9319UP8IX9319US8X9319US8IX9319US8IT1X9319US8IZX9319US8ZX9319WP8X9319WP8IX9319WS8X9319WS8IX9319WS8IT1X9319WS8IZX9319WS8IZT1X9319WS8T1X9319WS8ZX9319WS8ZT1
N1234567891011121314151617
Корпус8 Ld PDIP8 Ld PDIP8 Ld SOIC8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC8 Ld SOIC8 Ld PDIP8 Ld PDIP8 Ld SOIC8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC T+R8 Ld SOIC8 Ld SOIC T+R
Parameters / ModelsX9319UP8X9319UP8IX9319US8X9319US8IX9319US8IT1X9319US8IZX9319US8ZX9319WP8X9319WP8IX9319WS8X9319WS8IX9319WS8IT1X9319WS8IZX9319WS8IZT1X9319WS8T1X9319WS8ZX9319WS8ZT1
# of Taps100100100100100100100100100100100100100100100100100
Количество каналов11111111111111111
DescriptionDigitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)
Dual Supply Range (V)N/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/A
End-to-End Tempco (В±ppm/В°C)300300300300300300300300300300300300300300300300300
Основные особенностиInternal charge pump to generate terminal voltage capibility greater than VCCInternal charge pump to generate terminal voltage capibility greater than VCCInternal charge pump to generate terminal voltage capibility greater than VCCInternal charge pump to generate terminal voltage capibility greater than VCCInternal charge pump to generate terminal voltage capibility greater than VCCInternal charge pump to generate terminal voltage capibility greater than VCCInternal charge pump to generate terminal voltage capibility greater than VCCInternal charge pump to generate terminal voltage capibility greater than VCCInternal charge pump to generate terminal voltage capibility greater than VCCInternal charge pump to generate terminal voltage capibility greater than VCCInternal charge pump to generate terminal voltage capibility greater than VCCInternal charge pump to generate terminal voltage capibility greater than VCCInternal charge pump to generate terminal voltage capibility greater than VCCInternal charge pump to generate terminal voltage capibility greater than VCCInternal charge pump to generate terminal voltage capibility greater than VCCInternal charge pump to generate terminal voltage capibility greater than VCCInternal charge pump to generate terminal voltage capibility greater than VCC
ICC300 μA300 μA300 μA300 μA300 μA300 μA300 μA300 μA300 μA300 μA300 μA300 μA300 μA300 μA300 μA300 μA300 μA
Interface Type3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)
Max Operating Temp85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C
Memory TypeNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatile
Middlepoint Ratiometric Tempco2020202020202020202020202020202020
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Peak Temp240°C240°C240°C260°C260°C240°C240°C240°C260°C260°C240°C260°C260°C
Qualification LevelStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandard
Resistance Options (kΩ)1010101010101010101010101010101010
Resistance Options (kО©)1010101010101010101010101010101010
Resistance TaperLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinear
VCC (max)5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V
VCC (min)4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V
VL Max. Terminal Voltage10 V10 V10 V10 V10 V10 V10 V10 V10 V10 V10 V10 V10 V10 V10 V10 V10 V
VL Min. Terminal Voltage0 V0 V0 V0 V0 V0 V0 V0 V0 V0 V0 V0 V0 V0 V0 V0 V0 V
Wiper Current3 mA3 mA3 mA3 mA3 mA3 mA3 mA3 mA3 mA3 mA3 mA3 mA3 mA3 mA3 mA3 mA3 mA
Wiper Resistance40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©
Интерфейс3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)
RoHSСовместимСовместимСовместимСовместимСовместимСовместим
  • Data Converters > Digital Potentiometers (DCPs) > DCPs
На английском языке: Datasheet Intersil X9319
