Datasheet Intersil ISL23428 — Даташит
| Производитель | Intersil |
| Серия | ISL23428 |
Двойной низковольтный потенциометр с цифровым управлением на 128 отводов (XDCP)
|  Купить ISL23428 на РадиоЛоцман.Цены — от 34 до 207 ₽ 18 предложений от 18 поставщиков Dual, 128-Tap, Low Voltage Digitally Controlled Potentiometer (XDCP?) | IC DGTL POT 100KOHM 16UTQFN | |||
| ISL23428TFRUZ-TK Intersil | 73 ₽ | ||
| ISL23428TFRUZ-TK Renesas | по запросу | ||
| ISL23428TFVZ-TK Intersil | по запросу | ||
| ISL23428UFVZ-TK Intersil | по запросу | ||
| ISL23428TFRUZ-T7A | ISL23428TFRUZ-TK | ISL23428TFVZ | ISL23428TFVZ-T7A | ISL23428TFVZ-TK | ISL23428UFRUZ-T7A | ISL23428UFRUZ-TK | ISL23428UFVZ | ISL23428UFVZ-T7A | ISL23428UFVZ-TK | ISL23428WFRUZ-T7A | ISL23428WFRUZ-TK | ISL23428WFVZ | ISL23428WFVZ-T7A | ISL23428WFVZ-TK | |
| N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 |
| Корпус | 16 Ld uTQFN T+R | 16 Ld uTQFN T+R | 14 Ld TSSOP | 14 Ld TSSOP T+R | 14 Ld TSSOP T+R | 16 Ld uTQFN T+R | 16 Ld uTQFN T+R | 14 Ld TSSOP | 14 Ld TSSOP T+R | 14 Ld TSSOP T+R | 16 Ld uTQFN T+R | 16 Ld uTQFN T+R | 14 Ld TSSOP | 14 Ld TSSOP T+R | 14 Ld TSSOP T+R |
| Parameters / Models | ISL23428TFRUZ-T7A | ISL23428TFRUZ-TK | ISL23428TFVZ | ISL23428TFVZ-T7A | ISL23428TFVZ-TK | ISL23428UFRUZ-T7A | ISL23428UFRUZ-TK | ISL23428UFVZ | ISL23428UFVZ-T7A | ISL23428UFVZ-TK | ISL23428WFRUZ-T7A | ISL23428WFRUZ-TK | ISL23428WFVZ | ISL23428WFVZ-T7A | ISL23428WFVZ-TK |
| # of Taps | 128 | 128 | 128 | 128 | 128 | 128 | 128 | 128 | 128 | 128 | 128 | 128 | 128 | 128 | 128 |
| Количество каналов | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
| Description | Dual, 128-Tap, Low Voltage Digitally Controlled Potentiometer (XDCP?) | Dual, 128-Tap, Low Voltage Digitally Controlled Potentiometer (XDCP?) | Dual, 128-Tap, Low Voltage Digitally Controlled Potentiometer (XDCP?) | Dual, 128-Tap, Low Voltage Digitally Controlled Potentiometer (XDCP?) | Dual, 128-Tap, Low Voltage Digitally Controlled Potentiometer (XDCP?) | Dual, 128-Tap, Low Voltage Digitally Controlled Potentiometer (XDCP?) | Dual, 128-Tap, Low Voltage Digitally Controlled Potentiometer (XDCP?) | Dual, 128-Tap, Low Voltage Digitally Controlled Potentiometer (XDCP?) | Dual, 128-Tap, Low Voltage Digitally Controlled Potentiometer (XDCP?) | Dual, 128-Tap, Low Voltage Digitally Controlled Potentiometer (XDCP?) | Dual, 128-Tap, Low Voltage Digitally Controlled Potentiometer (XDCP?) | Dual, 128-Tap, Low Voltage Digitally Controlled Potentiometer (XDCP?) | Dual, 128-Tap, Low Voltage Digitally Controlled Potentiometer (XDCP?) | Dual, 128-Tap, Low Voltage Digitally Controlled Potentiometer (XDCP?) | Dual, 128-Tap, Low Voltage Digitally Controlled Potentiometer (XDCP?) |
| Dual Supply Range (V) | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A |
| End-to-End Tempco (В±ppm/В°C) | 125, 65, 45 | 125, 65, 45 | 125, 65, 45 | 125, 65, 45 | 125, 65, 45 | 125, 65, 45 | 125, 65, 45 | 125, 65, 45 | 125, 65, 45 | 125, 65, 45 | 125, 65, 45 | 125, 65, 45 | 125, 65, 45 | 125, 65, 45 | 125, 65, 45 |
| Основные особенности | VLOGIC 1.2V to 5.5V; Daisy Chainable to minimize # I/0 pins on microcontroller | VLOGIC 1.2V to 5.5V; Daisy Chainable to minimize # I/0 pins on microcontroller | VLOGIC 1.2V to 5.5V; Daisy Chainable to minimize # I/0 pins on microcontroller | VLOGIC 1.2V to 5.5V; Daisy Chainable to minimize # I/0 pins on microcontroller | VLOGIC 1.2V to 5.5V; Daisy Chainable to minimize # I/0 pins on microcontroller | VLOGIC 1.2V to 5.5V; Daisy Chainable to minimize # I/0 pins on microcontroller | VLOGIC 1.2V to 5.5V; Daisy Chainable to minimize # I/0 pins on microcontroller | VLOGIC 1.2V to 5.5V; Daisy Chainable to minimize # I/0 pins on microcontroller | VLOGIC 1.2V to 5.5V; Daisy Chainable to minimize # I/0 pins on microcontroller | VLOGIC 1.2V to 5.5V; Daisy Chainable to minimize # I/0 pins on microcontroller | VLOGIC 1.2V to 5.5V; Daisy Chainable to minimize # I/0 pins on microcontroller | VLOGIC 1.2V to 5.5V; Daisy Chainable to minimize # I/0 pins on microcontroller | VLOGIC 1.2V to 5.5V; Daisy Chainable to minimize # I/0 pins on microcontroller | VLOGIC 1.2V to 5.5V; Daisy Chainable to minimize # I/0 pins on microcontroller | VLOGIC 1.2V to 5.5V; Daisy Chainable to minimize # I/0 pins on microcontroller |
| ICC | 4 μA | 4 μA | 4 μA | 4 μA | 4 μA | 4 μA | 4 μA | 4 μA | 4 μA | 4 μA | 4 μA | 4 μA | 4 μA | 4 μA | 4 μA |
| Interface Type | SPI | SPI | SPI | SPI | SPI | SPI | SPI | SPI | SPI | SPI | SPI | SPI | SPI | SPI | SPI |
| Max Operating Temp | 125 °C | 125 °C | 125 °C | 125 °C | 125 °C | 125 °C | 125 °C | 125 °C | 125 °C | 125 °C | 125 °C | 125 °C | 125 °C | 125 °C | 125 °C |
| Memory Type | Volatile | Volatile | Volatile | Volatile | Volatile | Volatile | Volatile | Volatile | Volatile | Volatile | Volatile | Volatile | Volatile | Volatile | Volatile |
| Middlepoint Ratiometric Tempco | 8, 4, 2.3 | 8, 4, 2.3 | 8, 4, 2.3 | 8, 4, 2.3 | 8, 4, 2.3 | 8, 4, 2.3 | 8, 4, 2.3 | 8, 4, 2.3 | 8, 4, 2.3 | 8, 4, 2.3 | 8, 4, 2.3 | 8, 4, 2.3 | 8, 4, 2.3 | 8, 4, 2.3 | 8, 4, 2.3 |
| Рабочий диапазон температур | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 |
| Peak Temp | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C |
| Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
| Resistance Options (kΩ) | 10, 100 | 10, 100 | 10, 100 | 10, 100 | 10, 100 | 10, 100 | 10, 100 | 10, 100 | 10, 100 | 10, 100 | 10, 100 | 10, 100 | 10, 100 | 10, 100 | 10, 100 |
| Resistance Options (kО©) | 10, 100 | 10, 100 | 10, 100 | 10, 100 | 10, 100 | 10, 100 | 10, 100 | 10, 100 | 10, 100 | 10, 100 | 10, 100 | 10, 100 | 10, 100 | 10, 100 | 10, 100 |
| Resistance Taper | Linear | Linear | Linear | Linear | Linear | Linear | Linear | Linear | Linear | Linear | Linear | Linear | Linear | Linear | Linear |
| VCC (max) | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
| VCC (min) | 1.7 V | 1.7 V | 1.7 V | 1.7 V | 1.7 V | 1.7 V | 1.7 V | 1.7 V | 1.7 V | 1.7 V | 1.7 V | 1.7 V | 1.7 V | 1.7 V | 1.7 V |
| VL Max. Terminal Voltage | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
| VL Min. Terminal Voltage | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V |
| Wiper Current | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA |
| Wiper Resistance | 70 О© | 70 О© | 70 О© | 70 О© | 70 О© | 70 О© | 70 О© | 70 О© | 70 О© | 70 О© | 70 О© | 70 О© | 70 О© | 70 О© | 70 О© |
| Интерфейс | SPI | SPI | SPI | SPI | SPI | SPI | SPI | SPI | SPI | SPI | SPI | SPI | SPI | SPI | SPI |
| RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: ISL23428 (15)
- Data Converters > Digital Potentiometers (DCPs) > DCPs
