Datasheet Intersil ISL95810 — Даташит
Производитель | Intersil |
Серия | ISL95810 |
Одиночный потенциометр с цифровым управлением (XDCP)
![]() 13 предложений от 13 поставщиков Микросхема Цифровой потенциометр , Digital Potentiometer 256POS 10KΩ Single 8Pin MSOP | |||
ISL95810WIU8 Intersil | 55 ₽ | ||
ISL95810WIU8 Intersil | 66 ₽ | ||
ISL95810UIRT8 Intersil | по запросу |
ISL95810UIRT8 | ISL95810UIRT8Z | ISL95810UIRT8Z-T | ISL95810UIU8 | ISL95810UIU8-T | ISL95810UIU8Z | ISL95810UIU8Z-T | ISL95810WIRT8Z | ISL95810WIRT8Z-T | ISL95810WIU8 | ISL95810WIU8-T | ISL95810WIU8Z | |
N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 |
Корпус | 8 Ld DFN | 8 Ld DFN | 8 Ld DFN T+R | 8 Ld MSOP | 8 Ld MSOP T+R | 8 Ld MSOP | 8 Ld MSOP T+R | 8 Ld DFN | 8 Ld DFN T+R | 8 Ld MSOP | 8 Ld MSOP T+R | 8 Ld MSOP |
Parameters / Models | ISL95810UIRT8 | ISL95810UIRT8Z | ISL95810UIRT8Z-T | ISL95810UIU8 | ISL95810UIU8-T | ISL95810UIU8Z | ISL95810UIU8Z-T | ISL95810WIRT8Z | ISL95810WIRT8Z-T | ISL95810WIU8 | ISL95810WIU8-T | ISL95810WIU8Z |
# of Taps | 256 | 256 | 256 | 256 | 256 | 256 | 256 | 256 | 256 | 256 | 256 | 256 |
Количество каналов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Description | Single Digitally Controlled Potentiometer (XDCP?) | Single Digitally Controlled Potentiometer (XDCP?) | Single Digitally Controlled Potentiometer (XDCP?) | Single Digitally Controlled Potentiometer (XDCP?) | Single Digitally Controlled Potentiometer (XDCP?) | Single Digitally Controlled Potentiometer (XDCP?) | Single Digitally Controlled Potentiometer (XDCP?) | Single Digitally Controlled Potentiometer (XDCP?) | Single Digitally Controlled Potentiometer (XDCP?) | Single Digitally Controlled Potentiometer (XDCP?) | Single Digitally Controlled Potentiometer (XDCP?) | Single Digitally Controlled Potentiometer (XDCP?) |
Dual Supply Range (V) | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A |
End-to-End Tempco (В±ppm/В°C) | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 |
Основные особенности | Same as ISL90810 with memory | Same as ISL90810 with memory | Same as ISL90810 with memory | Same as ISL90810 with memory | Same as ISL90810 with memory | Same as ISL90810 with memory | Same as ISL90810 with memory | Same as ISL90810 with memory | Same as ISL90810 with memory | Same as ISL90810 with memory | Same as ISL90810 with memory | Same as ISL90810 with memory |
ICC | 5 μA | 5 μA | 5 μA | 5 μA | 5 μA | 5 μA | 5 μA | 5 μA | 5 μA | 5 μA | 5 μA | 5 μA |
Interface Type | I2C | I2C | I2C | I2C | I2C | I2C | I2C | I2C | I2C | I2C | I2C | I2C |
Max Operating Temp | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C |
Memory Type | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile |
Middlepoint Ratiometric Tempco | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Peak Temp | 240°C | 260°C | 260°C | 240°C | 240°C | 260°C | 260°C | 260°C | 260°C | 240°C | 240°C | 260°C |
Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
Resistance Options (kΩ) | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 |
Resistance Options (kО©) | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 |
Resistance Taper | Linear | Linear | Linear | Linear | Linear | Linear | Linear | Linear | Linear | Linear | Linear | Linear |
VCC (max) | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
VCC (min) | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V |
VL Max. Terminal Voltage | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
VL Min. Terminal Voltage | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V |
Wiper Current | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA |
Wiper Resistance | 70 О© | 70 О© | 70 О© | 70 О© | 70 О© | 70 О© | 70 О© | 70 О© | 70 О© | 70 О© | 70 О© | 70 О© |
Интерфейс | I2C | I2C | I2C | I2C | I2C | I2C | I2C | I2C | I2C | I2C | I2C | I2C |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: ISL95810 (12)
- Data Converters > Digital Potentiometers (DCPs) > DCPs
