Datasheet Intersil ISL23511 — Даташит
Производитель | Intersil |
Серия | ISL23511 |
Низкий уровень шума, малое энергопотребление, 32 отвода, потенциометр, управляемый кнопкой
![]() 10 предложений от 10 поставщиков Микросхема Цифровой потенциометр , Digital Potentiometer 32POS 50KΩ Single 8Pin SOIC N | |||
ISL23511UFB8Z Intersil | 40 ₽ | ||
ISL23511UFB8Z-TK | по запросу | ||
ISL23511UFB8Z Renesas | по запросу |
ISL23511UFB8Z | ISL23511UFB8Z-TK | ISL23511UFRU10Z-TK | ISL23511WFB8Z | ISL23511WFB8Z-TK | ISL23511WFRU10Z-TK | |
N | 1 | 2 | 3 | 4 | 5 | 6 |
Корпус | 8 Ld SOIC | 8 Ld SOIC T+R | 10 Ld uTQFN T+R | 8 Ld SOIC | 8 Ld SOIC T+R | 10 Ld uTQFN T+R |
Parameters / Models | ISL23511UFB8Z | ISL23511UFB8Z-TK | ISL23511UFRU10Z-TK | ISL23511WFB8Z | ISL23511WFB8Z-TK | ISL23511WFRU10Z-TK |
# of Taps | 32 | 32 | 32 | 32 | 32 | 32 |
Количество каналов | 1 | 1 | 1 | 1 | 1 | 1 |
Description | Low Noise, Low Power, 32 Taps, Push Button Controlled Potentiometer | Low Noise, Low Power, 32 Taps, Push Button Controlled Potentiometer | Low Noise, Low Power, 32 Taps, Push Button Controlled Potentiometer | Low Noise, Low Power, 32 Taps, Push Button Controlled Potentiometer | Low Noise, Low Power, 32 Taps, Push Button Controlled Potentiometer | Low Noise, Low Power, 32 Taps, Push Button Controlled Potentiometer |
Dual Supply Range (V) | N/A | N/A | N/A | N/A | N/A | N/A |
End-to-End Tempco (В±ppm/В°C) | 80 | 80 | 80 | 80 | 80 | 80 |
Основные особенности | Shutdown mode and auto increment | Shutdown mode and auto increment | Shutdown mode and auto increment | Shutdown mode and auto increment | Shutdown mode and auto increment | Shutdown mode and auto increment |
ICC | 0.6 μA | 0.6 μA | 0.6 μA | 0.6 μA | 0.6 μA | 0.6 μA |
Interface Type | Pushbutton | Pushbutton | Pushbutton | Pushbutton | Pushbutton | Pushbutton |
Max Operating Temp | 125 °C | 125 °C | 125 °C | 125 °C | 125 °C | 125 °C |
Memory Type | Volatile | Volatile | Volatile | Volatile | Volatile | Volatile |
Middlepoint Ratiometric Tempco | 25 | 25 | 25 | 25 | 25 | 25 |
Рабочий диапазон температур | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 |
Peak Temp | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C |
Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard |
Resistance Options (kΩ) | 10 | 10 | 10 | 10 | 10 | 10 |
Resistance Options (kО©) | 10 | 10 | 10 | 10 | 10 | 10 |
Resistance Taper | Linear | Linear | Linear | Linear | Linear | Linear |
VCC (max) | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
VCC (min) | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V |
VL Max. Terminal Voltage | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
VL Min. Terminal Voltage | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V |
Wiper Current | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA |
Wiper Resistance | 130 О© | 130 О© | 130 О© | 130 О© | 130 О© | 130 О© |
Интерфейс | Pushbutton | Pushbutton | Pushbutton | Pushbutton | Pushbutton | Pushbutton |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: ISL23511 (6)
- Data Converters > Digital Potentiometers (DCPs) > DCPs
