Datasheet Intersil X9C503 — Даташит
ПроизводительIntersil
СерияX9C503
Потенциометр с цифровым управлением (XDCP)
X9C102, X9C103, X9C104, X9C503 Datasheet
PDF, 529 Кб, Версия: 31-10-2017
43 предложений от 27 поставщиков
Энергонезависимый цифровой потенциометр, 50 кОм, Одиночный, Вверх, Вниз, Линейный, ± 20%, 4.5 В
X9C503SIZ
Intersil
71 ₽
X9C503SMC7000
TradeElectronics
X9C503SIZ-T1
Intersil
МосЧип
X9C503PIZ
Intersil
АЦП азиатских производителей
X9C503DMX9C503PX9C503PIX9C503PIZX9C503PMX9C503PZX9C503SX9C503SIX9C503SIT1X9C503SIT2X9C503SIZX9C503SIZT1X9C503SIZT2X9C503ST1X9C503ST2X9C503ST4X9C503SZX9C503SZT1X9C503SZT2
N12345678910111213141516171819
КорпусRetired - Please contact us for package data8 Ld PDIP8 Ld PDIP8 Ld PDIPRetired - Please contact us for package data8 Ld8 Ld PDIP8 Ld SOIC8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC T+R8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC T+R8 Ld SOIC T+R8 Ld SOIC T+R8 Ld SOIC T+R8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC T+R
Parameters / ModelsX9C503DMX9C503PX9C503PIX9C503PIZX9C503PMX9C503PZX9C503SX9C503SIX9C503SIT1X9C503SIT2X9C503SIZX9C503SIZT1X9C503SIZT2X9C503ST1X9C503ST2X9C503ST4X9C503SZX9C503SZT1X9C503SZT2
# of Taps100100100100100100100100100100100100100100100100100100100
Количество каналов1111111111111111111
DescriptionDigitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)
Dual Supply Range (V)N/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/A
End-to-End Tempco (В±ppm/В°C)300300300300300300300300300300300300300300300300300300300
Основные особенностиIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5V
ICC200 μA200 μA200 μA200 μA200 μA200 μA200 μA200 μA200 μA200 μA200 μA200 μA200 μA200 μA200 μA200 μA200 μA200 μA200 μA
Interface Type3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)
Max Operating Temp85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C
Memory TypeNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatile
Middlepoint Ratiometric Tempco20202020202020202020202020202020202020
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Peak Temp240°C240°C240°C240°C260°C260°C260°C240°C240°C240°C260°C260°C260°C
Qualification LevelStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandard
Resistance Options (kΩ)50505050505050505050505050505050505050
Resistance Options (kО©)50505050505050505050505050505050505050
Resistance TaperLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinear
VCC (max)5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V
VCC (min)4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V
VL Max. Terminal Voltage5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V
VL Min. Terminal Voltage-5 V-5 V-5 V-5 V-5 V-5 V-5 V-5 V-5 V-5 V-5 V-5 V-5 V-5 V-5 V-5 V-5 V-5 V-5 V
Wiper Current4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA
Wiper Resistance40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©
Интерфейс3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
X9C102 X9C103 X9C104
  • Data Converters > Digital Potentiometers (DCPs) > DCPs
На английском языке: Datasheet Intersil X9C503
