Datasheet Intersil ISL90461 — Даташит
ПроизводительIntersil
СерияISL90461
Одиночный энергозависимый 32-кратный потенциометр с цифровым управлением (XDCP)
ISL90461 Datasheet
PDF, 391 Кб, Версия: 26-10-2017
ISL90461UIE6
Intersil
ISL90461UIH627
Intersil
ТаймЧипс
ISL90461WIE627
Intersil
LifeElectronics
ISL90461TIE627
Intersil
ISL90461TIE627-TKISL90461TIE627Z-TKISL90461TIH627-TKISL90461TIH627Z-TKISL90461UIE6ISL90461UIE627-TKISL90461UIE627Z-TKISL90461UIH627-TKISL90461UIH627Z-TKISL90461WIE627-TKISL90461WIE627Z-TKISL90461WIH627-TKISL90461WIH627Z-TK
N12345678910111213
Корпус6 Ld SC70 T+R6 Ld SC70 T+R6 Ld SOT T+R6 Ld SOT T+R6 Ld SC706 Ld SC70 T+R6 Ld SC70 T+R6 Ld SOT T+R6 Ld SOT T+R6 Ld SC70 T+R6 Ld SC70 T+R6 Ld SOT T+R6 Ld SOT T+R
Parameters / ModelsISL90461TIE627-TKISL90461TIE627Z-TKISL90461TIH627-TKISL90461TIH627Z-TKISL90461UIE6ISL90461UIE627-TKISL90461UIE627Z-TKISL90461UIH627-TKISL90461UIH627Z-TKISL90461WIE627-TKISL90461WIE627Z-TKISL90461WIH627-TKISL90461WIH627Z-TK
# of Taps32323232323232323232323232
Количество каналов1111111111111
DescriptionSingle Volatile 32-Tap Digitally Controlled Potentiometer (XDCP?)Single Volatile 32-Tap Digitally Controlled Potentiometer (XDCP?)Single Volatile 32-Tap Digitally Controlled Potentiometer (XDCP?)Single Volatile 32-Tap Digitally Controlled Potentiometer (XDCP?)Single Volatile 32-Tap Digitally Controlled Potentiometer (XDCP?)Single Volatile 32-Tap Digitally Controlled Potentiometer (XDCP?)Single Volatile 32-Tap Digitally Controlled Potentiometer (XDCP?)Single Volatile 32-Tap Digitally Controlled Potentiometer (XDCP?)Single Volatile 32-Tap Digitally Controlled Potentiometer (XDCP?)Single Volatile 32-Tap Digitally Controlled Potentiometer (XDCP?)Single Volatile 32-Tap Digitally Controlled Potentiometer (XDCP?)Single Volatile 32-Tap Digitally Controlled Potentiometer (XDCP?)Single Volatile 32-Tap Digitally Controlled Potentiometer (XDCP?)
Dual Supply Range (V)N/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/A
End-to-End Tempco (В±ppm/В°C)35353535353535353535353535
Основные особенностиRheostat with pined our RH and RLRheostat with pined our RH and RLRheostat with pined our RH and RLRheostat with pined our RH and RLRheostat with pined our RH and RLRheostat with pined our RH and RLRheostat with pined our RH and RLRheostat with pined our RH and RLRheostat with pined our RH and RLRheostat with pined our RH and RLRheostat with pined our RH and RLRheostat with pined our RH and RLRheostat with pined our RH and RL
ICC0.3 μA0.3 μA0.3 μA0.3 μA0.3 μA0.3 μA0.3 μA0.3 μA0.3 μA0.3 μA0.3 μA0.3 μA0.3 μA
Interface Type2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)
Max Operating Temp85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C
Memory TypeVolatileVolatileVolatileVolatileVolatileVolatileVolatileVolatileVolatileVolatileVolatileVolatileVolatile
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Peak Temp240°C260°C240°C260°C240°C240°C260°C240°C260°C240°C260°C240°C260°C
Qualification LevelStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandard
Resistance Options (kΩ)10, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 100
Resistance Options (kО©)10, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 100
Resistance TaperLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinear
VCC (max)5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V
VCC (min)2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V
VL Max. Terminal Voltage5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V
VL Min. Terminal Voltage0 V0 V0 V0 V0 V0 V0 V0 V0 V0 V0 V0 V0 V
Wiper Current.6 mA.6 mA.6 mA.6 mA.6 mA.6 mA.6 mA.6 mA.6 mA.6 mA.6 mA.6 mA.6 mA
Wiper Resistance600 О©600 О©600 О©600 О©600 О©600 О©600 О©600 О©600 О©600 О©600 О©600 О©600 О©
Интерфейс2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)
RoHSСовместимСовместимСовместимСовместимСовместимСовместим
  • Data Converters > Digital Potentiometers (DCPs) > DCPs
На английском языке: Datasheet Intersil ISL90461
