Datasheet Intersil ISL90462 — Даташит
ПроизводительIntersil
СерияISL90462
Одиночный энергозависимый 32-кратный потенциометр с цифровым управлением (XDCP)
ISL90462 Datasheet
PDF, 423 Кб, Версия: 26-10-2017
7 предложений от 7 поставщиков
, 100K DIGITAL POTENTIOMETER, INCREMENT/DECREMENT CONTROL INTERFACE, 32 POSITIONS, PDSO6, PLASTIC, SC-70, MO-203-AB, 6 PIN
ISL90462TIE627
Intersil
34 ₽
ISL90462TIE627
Intersil
36 ₽
ISL90462TIE627
Intersil
36 ₽
ISL90462
Intersil
ISL90462TIE627-TKISL90462TIE627Z-TKISL90462TIH627-TKISL90462TIH627Z-TKISL90462UIE6ISL90462UIE627-TKISL90462UIE627Z-TKISL90462UIH627-TKISL90462UIH627Z-TKISL90462WIE627-TKISL90462WIE627Z-TKISL90462WIH627-TKISL90462WIH627Z-TK
N12345678910111213
Корпус6 Ld SC70 T+R6 Ld SC70 T+R6 Ld SOT T+R6 Ld SOT T+R6 Ld SC706 Ld SC70 T+R6 Ld SC70 T+R6 Ld SOT T+R6 Ld SOT T+R6 Ld SC70 T+R6 Ld SC70 T+R6 Ld SOT T+R6 Ld SOT T+R
Parameters / ModelsISL90462TIE627-TKISL90462TIE627Z-TKISL90462TIH627-TKISL90462TIH627Z-TKISL90462UIE6ISL90462UIE627-TKISL90462UIE627Z-TKISL90462UIH627-TKISL90462UIH627Z-TKISL90462WIE627-TKISL90462WIE627Z-TKISL90462WIH627-TKISL90462WIH627Z-TK
# of Taps32323232323232323232323232
Количество каналов1111111111111
DescriptionSingle Volatile 32-tap Digitally Controlled Potentiometer (XDCP?)Single Volatile 32-tap Digitally Controlled Potentiometer (XDCP?)Single Volatile 32-tap Digitally Controlled Potentiometer (XDCP?)Single Volatile 32-tap Digitally Controlled Potentiometer (XDCP?)Single Volatile 32-tap Digitally Controlled Potentiometer (XDCP?)Single Volatile 32-tap Digitally Controlled Potentiometer (XDCP?)Single Volatile 32-tap Digitally Controlled Potentiometer (XDCP?)Single Volatile 32-tap Digitally Controlled Potentiometer (XDCP?)Single Volatile 32-tap Digitally Controlled Potentiometer (XDCP?)Single Volatile 32-tap Digitally Controlled Potentiometer (XDCP?)Single Volatile 32-tap Digitally Controlled Potentiometer (XDCP?)Single Volatile 32-tap Digitally Controlled Potentiometer (XDCP?)Single Volatile 32-tap Digitally Controlled Potentiometer (XDCP?)
Dual Supply Range (V)N/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/A
End-to-End Tempco (В±ppm/В°C)35353535353535353535353535
Основные особенностиVoltage divider or Rheostat with RL connected to GNDVoltage divider or Rheostat with RL connected to GNDVoltage divider or Rheostat with RL connected to GNDVoltage divider or Rheostat with RL connected to GNDVoltage divider or Rheostat with RL connected to GNDVoltage divider or Rheostat with RL connected to GNDVoltage divider or Rheostat with RL connected to GNDVoltage divider or Rheostat with RL connected to GNDVoltage divider or Rheostat with RL connected to GNDVoltage divider or Rheostat with RL connected to GNDVoltage divider or Rheostat with RL connected to GNDVoltage divider or Rheostat with RL connected to GNDVoltage divider or Rheostat with RL connected to GND
ICC0.3 μA0.3 μA0.3 μA0.3 μA0.3 μA0.3 μA0.3 μA0.3 μA0.3 μA0.3 μA0.3 μA0.3 μA0.3 μA
Interface Type2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)
Max Operating Temp85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C
Memory TypeVolatileVolatileVolatileVolatileVolatileVolatileVolatileVolatileVolatileVolatileVolatileVolatileVolatile
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Peak Temp240°C260°C240°C260°C240°C240°C260°C240°C260°C240°C260°C240°C260°C
Qualification LevelStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandard
Resistance Options (kΩ)10, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 100
Resistance Options (kО©)10, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 10010, 50, 100
Resistance TaperLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinear
VCC (max)5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V
VCC (min)2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V
VL Max. Terminal Voltage5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V
VL Min. Terminal Voltage0 V0 V0 V0 V0 V0 V0 V0 V0 V0 V0 V0 V0 V
Wiper Current.6 mA.6 mA.6 mA.6 mA.6 mA.6 mA.6 mA.6 mA.6 mA.6 mA.6 mA.6 mA.6 mA
Wiper Resistance600 О©600 О©600 О©600 О©600 О©600 О©600 О©600 О©600 О©600 О©600 О©600 О©600 О©
Интерфейс2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)2-Pin (Up/Down)
RoHSСовместимСовместимСовместимСовместимСовместимСовместим
  • Data Converters > Digital Potentiometers (DCPs) > DCPs
На английском языке: Datasheet Intersil ISL90462
