Datasheet Intersil ISL22326 — Даташит
ПроизводительIntersil
СерияISL22326
Двойной потенциометр с цифровым управлением; Низкий уровень шума, малое энергопотребление, шина I 2 C, 128 ответвлений
ISL22326 Datasheet
PDF, 990 Кб, Версия: 04-10-2017
5 предложений от 5 поставщиков
Traceability Through Assembly and Test by Date/Trace Code Assignment $ Enhanced Process Change Notification $ Enhanced Obsolescence Management $ Eliminates
ISL22326WMVEP-TK
Intersil
450 ₽
ISL22326WMVEP-TK
Intersil
450 ₽
ISL22326WMVEP-TK
Renesas
ISL22326WMVEP
Intersil
ISL22326UFR16ZISL22326UFR16Z-TKISL22326UFV14ZISL22326UFV14Z-TKISL22326WFR16ZISL22326WFR16Z-TKISL22326WFV14ZISL22326WFV14Z-TK
N12345678
Корпус16 Ld QFN16 Ld QFN T+R14 Ld TSSOP14 Ld TSSOP T+R16 Ld QFN16 Ld QFN T+R14 Ld TSSOP14 Ld TSSOP T+R
Parameters / ModelsISL22326UFR16ZISL22326UFR16Z-TKISL22326UFV14ZISL22326UFV14Z-TKISL22326WFR16ZISL22326WFR16Z-TKISL22326WFV14ZISL22326WFV14Z-TK
# of Taps128128128128128128128128
Количество каналов22222222
DescriptionDual Digitally Controlled Potentiometer; Low Noise, Low Power, I2C Bus, 128 TapsDual Digitally Controlled Potentiometer; Low Noise, Low Power, I2C Bus, 128 TapsDual Digitally Controlled Potentiometer; Low Noise, Low Power, I2C Bus, 128 TapsDual Digitally Controlled Potentiometer; Low Noise, Low Power, I2C Bus, 128 TapsDual Digitally Controlled Potentiometer; Low Noise, Low Power, I2C Bus, 128 TapsDual Digitally Controlled Potentiometer; Low Noise, Low Power, I2C Bus, 128 TapsDual Digitally Controlled Potentiometer; Low Noise, Low Power, I2C Bus, 128 TapsDual Digitally Controlled Potentiometer; Low Noise, Low Power, I2C Bus, 128 Taps
Dual Supply Range (V)N/AN/AN/AN/AN/AN/AN/AN/A
End-to-End Tempco (В±ppm/В°C)5050505050505050
Основные особенности3 terminal DCP with 6 bytes general purpose EEPROM3 terminal DCP with 6 bytes general purpose EEPROM3 terminal DCP with 6 bytes general purpose EEPROM3 terminal DCP with 6 bytes general purpose EEPROM3 terminal DCP with 6 bytes general purpose EEPROM3 terminal DCP with 6 bytes general purpose EEPROM3 terminal DCP with 6 bytes general purpose EEPROM3 terminal DCP with 6 bytes general purpose EEPROM
ICC5 μA5 μA5 μA5 μA5 μA5 μA5 μA5 μA
Interface TypeI2CI2CI2CI2CI2CI2CI2CI2C
Max Operating Temp125 °C125 °C125 °C125 °C125 °C125 °C125 °C125 °C
Memory TypeNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatile
Middlepoint Ratiometric Tempco44444444
Рабочий диапазон температурот -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125
Peak Temp260°C260°C260°C260°C260°C260°C260°C260°C
Qualification LevelStandardStandardStandardStandardStandardStandardStandardStandard
Resistance Options (kΩ)1010101010101010
Resistance Options (kО©)1010101010101010
Resistance TaperLinearLinearLinearLinearLinearLinearLinearLinear
VCC (max)5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V
VCC (min)2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V
VL Max. Terminal Voltage5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V
VL Min. Terminal Voltage0 V0 V0 V0 V0 V0 V0 V0 V
Wiper Current3 mA3 mA3 mA3 mA3 mA3 mA3 mA3 mA
Wiper Resistance70 О©70 О©70 О©70 О©70 О©70 О©70 О©70 О©
ИнтерфейсI2CI2CI2CI2CI2CI2CI2CI2C
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
  • Data Converters > Digital Potentiometers (DCPs) > DCPs
На английском языке: Datasheet Intersil ISL22326
