Datasheet Intersil ISL90841 — Даташит
| Производитель | Intersil |
| Серия | ISL90841 |
Счетверенные потенциометры с цифровым управлением (XDCP)
Low Noise, Low Power I2C Bus, 256 Taps | |||
| ISL90841WIV1427 Intersil | по запросу | ||
| ISL90841UIV1427 Intersil | по запросу | ||
| ISL90841 Intersil | по запросу | ||
| ISL90841UIV1427Z | ISL90841UIV1427Z-TK | ISL90841WIV1427Z | ISL90841WIV1427Z-TK | |
| N | 1 | 2 | 3 | 4 |
| Корпус | 14 Ld TSSOP | 14 Ld TSSOP T+R | 14 Ld TSSOP | 14 Ld TSSOP T+R |
| Parameters / Models | ISL90841UIV1427Z | ISL90841UIV1427Z-TK | ISL90841WIV1427Z | ISL90841WIV1427Z-TK |
| # of Taps | 256 | 256 | 256 | 256 |
| Количество каналов | 4 | 4 | 4 | 4 |
| Description | Quad Digitally Controlled Potentiometers (XDCP?) | Quad Digitally Controlled Potentiometers (XDCP?) | Quad Digitally Controlled Potentiometers (XDCP?) | Quad Digitally Controlled Potentiometers (XDCP?) |
| Dual Supply Range (V) | N/A | N/A | N/A | N/A |
| End-to-End Tempco (В±ppm/В°C) | 45 | 45 | 45 | 45 |
| Основные особенности | 2-terminal - voltage divider or rheostat usage | 2-terminal - voltage divider or rheostat usage | 2-terminal - voltage divider or rheostat usage | 2-terminal - voltage divider or rheostat usage |
| ICC | 5 μA | 5 μA | 5 μA | 5 μA |
| Interface Type | I2C | I2C | I2C | I2C |
| Max Operating Temp | 85 °C | 85 °C | 85 °C | 85 °C |
| Memory Type | Volatile | Volatile | Volatile | Volatile |
| Middlepoint Ratiometric Tempco | 4 | 4 | 4 | 4 |
| Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
| Peak Temp | 260°C | 260°C | 260°C | 260°C |
| Qualification Level | Standard | Standard | Standard | Standard |
| Resistance Options (kΩ) | 10, 50 | 10, 50 | 10, 50 | 10, 50 |
| Resistance Options (kО©) | 10, 50 | 10, 50 | 10, 50 | 10, 50 |
| Resistance Taper | Linear | Linear | Linear | Linear |
| VCC (max) | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
| VCC (min) | 2.7 V | 2.7 V | 2.7 V | 2.7 V |
| VL Max. Terminal Voltage | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
| VL Min. Terminal Voltage | 0 V | 0 V | 0 V | 0 V |
| Wiper Current | 3 mA | 3 mA | 3 mA | 3 mA |
| Wiper Resistance | 70 О© | 70 О© | 70 О© | 70 О© |
| Интерфейс | I2C | I2C | I2C | I2C |
| RoHS | Совместим | Совместим | Совместим | Совместим |
Серия: ISL90841 (4)
- Data Converters > Digital Potentiometers (DCPs) > DCPs
