Datasheet Intersil ISL95311 — Даташит
ПроизводительIntersil
СерияISL95311
Потенциометр с цифровым управлением (XDCP)
ISL95311 Datasheet
PDF, 597 Кб, Версия: 15-11-2017
Terminal Voltage 0V to 13.2V, 128 Taps I2C Interface
ISL95311WPI
Xicor
TradeElectronics
ISL95311
Intersil
ISL95311UIU10ZISL95311UIU10Z-TKISL95311WIP14ZISL95311WIU10ZISL95311WIU10Z-TK
N12345
Корпус10 Ld MSOP10 Ld MSOP T+RRetired - Please contact us for package data14 Ld PDIP10 Ld MSOP10 Ld MSOP T+R
Parameters / ModelsISL95311UIU10ZISL95311UIU10Z-TKISL95311WIP14ZISL95311WIU10ZISL95311WIU10Z-TK
# of Taps128128128128128
Количество каналов11111
DescriptionDigitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)
Dual Supply Range (V)8 to 13.28 to 13.28 to 13.28 to 13.28 to 13.2
End-to-End Tempco (В±ppm/В°C)4545454545
Основные особенностиDual supply required to obtain terminal voltage higher than VccDual supply required to obtain terminal voltage higher than VccDual supply required to obtain terminal voltage higher than VccDual supply required to obtain terminal voltage higher than VccDual supply required to obtain terminal voltage higher than Vcc
ICC5 μA5 μA5 μA5 μA5 μA
Interface TypeI2CI2CI2CI2CI2C
Max Operating Temp85 °C85 °C85 °C85 °C85 °C
Memory TypeNonvolatileNonvolatileNonvolatileNonvolatileNonvolatile
Middlepoint Ratiometric Tempco44444
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Peak Temp260°C260°C260°C260°C
Qualification LevelStandardStandardStandardStandardStandard
Resistance Options (kΩ)1010101010
Resistance Options (kО©)1010101010
Resistance TaperLinearLinearLinearLinearLinear
VCC (max)5.5 V5.5 V5.5 V5.5 V5.5 V
VCC (min)2.7 V2.7 V2.7 V2.7 V2.7 V
VL Max. Terminal Voltage13.2 V13.2 V13.2 V13.2 V13.2 V
VL Min. Terminal Voltage0 V0 V0 V0 V0 V
Wiper Current3 mA3 mA3 mA3 mA3 mA
Wiper Resistance70 О©70 О©70 О©70 О©70 О©
ИнтерфейсI2CI2CI2CI2CI2C
RoHSСовместимСовместимСовместимСовместим
  • Data Converters > Digital Potentiometers (DCPs) > DCPs
На английском языке: Datasheet Intersil ISL95311
