Datasheet Intersil ISL95310 — Даташит
ПроизводительIntersil
СерияISL95310
Потенциометр с цифровым управлением (XDCP)
ISL95310 Datasheet
PDF, 480 Кб, Версия: 15-11-2017
36 предложений от 16 поставщиков
, Digital Potentiometer 50kΩ 128POS Non-Volatile Linear Automotive 10Pin MSOP Tube
727GS
ISL95310UIU10Z
Intersil
25 ₽
ISL95310UIU10Z
Renesas
107 ₽
ISL95310UIU10Z
Renesas
от 269 ₽
ISL95310UIU10Z-TK
Intersil
ISL95310UIU10ZISL95310UIU10Z-TKISL95310WIU10ZISL95310WIU10Z-TK
N1234
Корпус10 Ld MSOP10 Ld MSOP T+R10 Ld MSOP10 Ld MSOP T+R
Parameters / ModelsISL95310UIU10ZISL95310UIU10Z-TKISL95310WIU10ZISL95310WIU10Z-TK
# of Taps128128128128
Количество каналов1111
DescriptionDigitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)
Dual Supply Range (V)8 to 13.28 to 13.28 to 13.28 to 13.2
End-to-End Tempco (В±ppm/В°C)45454545
Основные особенностиDual supply required to obtain terminal voltage higher than VccDual supply required to obtain terminal voltage higher than VccDual supply required to obtain terminal voltage higher than VccDual supply required to obtain terminal voltage higher than Vcc
ICC5 μA5 μA5 μA5 μA
Interface Type3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)
Max Operating Temp85 °C85 °C85 °C85 °C
Memory TypeNonvolatileNonvolatileNonvolatileNonvolatile
Middlepoint Ratiometric Tempco4444
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85
Peak Temp260°C260°C260°C260°C
Qualification LevelStandardStandardStandardStandard
Resistance Options (kΩ)50505050
Resistance Options (kО©)50505050
Resistance TaperLinearLinearLinearLinear
VCC (max)5.5 V5.5 V5.5 V5.5 V
VCC (min)2.7 V2.7 V2.7 V2.7 V
VL Max. Terminal Voltage13.2 V13.2 V13.2 V13.2 V
VL Min. Terminal Voltage0 V0 V0 V0 V
Wiper Current3 mA3 mA3 mA3 mA
Wiper Resistance70 О©70 О©70 О©70 О©
Интерфейс3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)
RoHSСовместимСовместимСовместимСовместим
  • Data Converters > Digital Potentiometers (DCPs) > DCPs
На английском языке: Datasheet Intersil ISL95310
