Datasheet Intersil X95840 — Даташит
| Производитель | Intersil |
| Серия | X95840 |
Четырехпозиционные потенциометры с цифровым управлением (XDCP); Низкий уровень шума/низкая мощность/шина I 2 C/256 ответвителей
| 6 предложений от 6 поставщиков Quad Digital Controlled Potentiometers | |||
| X95840 | по запросу | ||
| X95840_06 Intersil | по запросу | ||
| X95840UVG Intersil | по запросу | ||
| X95840 Intersil | по запросу | ||
| X95840UV20I-2.7 | X95840UV20I-2.7T1 | X95840UV20IZ-2.7 | X95840UV20IZ-2.7T1 | X95840WP20I-2.7 | X95840WV20I-2.7 | X95840WV20I-2.7T1 | X95840WV20IZ-2.7 | X95840WV20IZ-2.7T1 | |
| N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 |
| Корпус | Retired - Please contact us for package data20 Ld TSSOP | Retired - Please contact us for package data20 Ld TSSOP T+R | 20 Ld TSSOP | 20 Ld TSSOP T+R | Retired - Please contact us for package data | Retired - Please contact us for package data20 Ld TSSOP | Retired - Please contact us for package data20 Ld TSSOP T+R | 20 Ld TSSOP | 20 Ld TSSOP T+R |
| Parameters / Models | X95840UV20I-2.7 | X95840UV20I-2.7T1 | X95840UV20IZ-2.7 | X95840UV20IZ-2.7T1 | X95840WP20I-2.7 | X95840WV20I-2.7 | X95840WV20I-2.7T1 | X95840WV20IZ-2.7 | X95840WV20IZ-2.7T1 |
| # of Taps | 256 | 256 | 256 | 256 | 256 | 256 | 256 | 256 | 256 |
| Количество каналов | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 |
| Description | Quad Digital Controlled Potentiometers (XDCP?); Low Noise/Low Power/I2C Bus/256 Taps | Quad Digital Controlled Potentiometers (XDCP?); Low Noise/Low Power/I2C Bus/256 Taps | Quad Digital Controlled Potentiometers (XDCP?); Low Noise/Low Power/I2C Bus/256 Taps | Quad Digital Controlled Potentiometers (XDCP?); Low Noise/Low Power/I2C Bus/256 Taps | Quad Digital Controlled Potentiometers (XDCP?); Low Noise/Low Power/I2C Bus/256 Taps | Quad Digital Controlled Potentiometers (XDCP?); Low Noise/Low Power/I2C Bus/256 Taps | Quad Digital Controlled Potentiometers (XDCP?); Low Noise/Low Power/I2C Bus/256 Taps | Quad Digital Controlled Potentiometers (XDCP?); Low Noise/Low Power/I2C Bus/256 Taps | Quad Digital Controlled Potentiometers (XDCP?); Low Noise/Low Power/I2C Bus/256 Taps |
| Dual Supply Range (V) | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A |
| End-to-End Tempco (В±ppm/В°C) | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 |
| Основные особенности | Quad version of ISL95810 | Quad version of ISL95810 | Quad version of ISL95810 | Quad version of ISL95810 | Quad version of ISL95810 | Quad version of ISL95810 | Quad version of ISL95810 | Quad version of ISL95810 | Quad version of ISL95810 |
| ICC | 5 μA | 5 μA | 5 μA | 5 μA | 5 μA | 5 μA | 5 μA | 5 μA | 5 μA |
| Interface Type | I2C | I2C | I2C | I2C | I2C | I2C | I2C | I2C | I2C |
| Max Operating Temp | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C |
| Memory Type | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile |
| Middlepoint Ratiometric Tempco | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 |
| Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
| Peak Temp | 240°C | 240°C | 260°C | 260°C | 240°C | 240°C | 260°C | 260°C | |
| Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
| Resistance Options (kΩ) | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 |
| Resistance Options (kО©) | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 | 10, 50 |
| Resistance Taper | Linear | Linear | Linear | Linear | Linear | Linear | Linear | Linear | Linear |
| VCC (max) | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
| VCC (min) | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V |
| VL Max. Terminal Voltage | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
| VL Min. Terminal Voltage | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V |
| Wiper Current | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA |
| Wiper Resistance | 70 О© | 70 О© | 70 О© | 70 О© | 70 О© | 70 О© | 70 О© | 70 О© | 70 О© |
| Интерфейс | I2C | I2C | I2C | I2C | I2C | I2C | I2C | I2C | I2C |
| RoHS | Совместим | Совместим | Совместим | Совместим |
Серия: X95840 (9)
- Data Converters > Digital Potentiometers (DCPs) > DCPs
