Datasheet Intersil ISL22316 — Даташит
ПроизводительIntersil
СерияISL22316
Low Noise, Low Power I2CВ® Bus, 128 Taps
ISL22316 Datasheet
PDF, 951 Кб, Версия: 04-10-2017
5 предложений от 5 поставщиков
Микросхема Цифровой потенциометр , Digital Potentiometer 128POS 10KΩ Single 10Pin MSOP T/R
ISL22316WMUEP-TK
Intersil
293 ₽
ISL22316WMUEP-TK
Intersil
360 ₽
ISL22316WMUEP
Renesas
ISL22316
Intersil
ISL22316UFRT10ZISL22316UFRT10Z-TKISL22316UFU10ZISL22316UFU10Z-TKISL22316WFRT10ZISL22316WFRT10Z-TKISL22316WFU10ZISL22316WFU10Z-TK
N12345678
Корпус10 Ld DFN10 Ld DFN T+R10 Ld MSOP10 Ld MSOP T+R10 Ld DFN10 Ld DFN T+R10 Ld MSOP10 Ld MSOP T+R
Parameters / ModelsISL22316UFRT10ZISL22316UFRT10Z-TKISL22316UFU10ZISL22316UFU10Z-TKISL22316WFRT10ZISL22316WFRT10Z-TKISL22316WFU10ZISL22316WFU10Z-TK
# of Taps128128128128128128128128
Количество каналов11111111
DescriptionLow Noise, Low Power I2C? Bus, 128 TapsLow Noise, Low Power I2C? Bus, 128 TapsLow Noise, Low Power I2C? Bus, 128 TapsLow Noise, Low Power I2C? Bus, 128 TapsLow Noise, Low Power I2C? Bus, 128 TapsLow Noise, Low Power I2C? Bus, 128 TapsLow Noise, Low Power I2C? Bus, 128 TapsLow Noise, Low Power I2C? Bus, 128 Taps
Dual Supply Range (V)N/AN/AN/AN/AN/AN/AN/AN/A
End-to-End Tempco (В±ppm/В°C)5050505050505050
Основные особенности3 terminal DCP with shutdown feature3 terminal DCP with shutdown feature3 terminal DCP with shutdown feature3 terminal DCP with shutdown feature3 terminal DCP with shutdown feature3 terminal DCP with shutdown feature3 terminal DCP with shutdown feature3 terminal DCP with shutdown feature
ICC5 μA5 μA5 μA5 μA5 μA5 μA5 μA5 μA
Interface TypeI2CI2CI2CI2CI2CI2CI2CI2C
Max Operating Temp125 °C125 °C125 °C125 °C125 °C125 °C125 °C125 °C
Memory TypeNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatile
Middlepoint Ratiometric Tempco44444444
Рабочий диапазон температурот -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125
Peak Temp260°C260°C260°C260°C260°C260°C260°C260°C
Qualification LevelStandardStandardStandardStandardStandardStandardStandardStandard
Resistance Options (kΩ)1010101010101010
Resistance Options (kО©)1010101010101010
Resistance TaperLinearLinearLinearLinearLinearLinearLinearLinear
VCC (max)5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V
VCC (min)2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V
VL Max. Terminal Voltage5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V
VL Min. Terminal Voltage0 V0 V0 V0 V0 V0 V0 V0 V
Wiper Current3 mA3 mA3 mA3 mA3 mA3 mA3 mA3 mA
Wiper Resistance70 О©70 О©70 О©70 О©70 О©70 О©70 О©70 О©
ИнтерфейсI2CI2CI2CI2CI2CI2CI2CI2C
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
  • Data Converters > Digital Potentiometers (DCPs) > DCPs
На английском языке: Datasheet Intersil ISL22316
