Datasheet Intersil ISL267450 — Даташит
Производитель | Intersil |
Серия | ISL267450 |
12-разрядные АЦП SAR со скоростью 1 MSPS
![]() 20 предложений от 17 поставщиков Аналого-цифровые преобразователи (АЦП) 12 BIT 1MSPS SAR ADC 8LD 3 X 3 PROPRIETRY | |||
ISL267450IBZ-T Intersil | 308 ₽ | ||
ISL267450IBZ-T Renesas | 495 ₽ | ||
ISL267450IUZ Renesas | 890 ₽ | ||
ISL267450IBZ-T Intersil | по запросу |
ISL267450IBZ | ISL267450IBZ-T | ISL267450IBZ-T7A | ISL267450IUZ | ISL267450IUZ-T | ISL267450IUZ-T7A | |
N | 1 | 2 | 3 | 4 | 5 | 6 |
Корпус | 8 Ld SOIC | 8 Ld SOIC T+R | 8 Ld SOIC T+R | 8 Ld MSOP | 8 Ld MSOP T+R | 8 Ld MSOP T+R |
Parameters / Models | ISL267450IBZ | ISL267450IBZ-T | ISL267450IBZ-T7A | ISL267450IUZ | ISL267450IUZ-T | ISL267450IUZ-T7A |
± DNL (Diff. Non-Linearity) (LSB) | 0.95 | 0.95 | 0.95 | 0.95 | 0.95 | 0.95 |
± INL (Integral Non-Linearity) (LSB) | 1 | 1 | 1 | 1 | 1 | 1 |
Analog Supply Voltage (max) (V) | 5.25 V | 5.25 V | 5.25 V | 5.25 V | 5.25 V | 5.25 V |
Analog Supply Voltage (min) (V) | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V |
Количество каналов | 1 | 1 | 1 | 1 | 1 | 1 |
Description | 12-Bit, 1MSPS SAR ADCs | 12-Bit, 1MSPS SAR ADCs | 12-Bit, 1MSPS SAR ADCs | 12-Bit, 1MSPS SAR ADCs | 12-Bit, 1MSPS SAR ADCs | 12-Bit, 1MSPS SAR ADCs |
Max Conv Rate (kSPS) | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Peak Temp | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C |
Power Consumption | 3.75 mW | 3.75 mW | 3.75 mW | 3.75 mW | 3.75 mW | 3.75 mW |
Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard |
Разрешение | 12 | 12 | 12 | 12 | 12 | 12 |
SFDR | -82 dB | -82 dB | -82 dB | -82 dB | -82 dB | -82 dB |
SINAD | 70 dbFS | 70 dbFS | 70 dbFS | 70 dbFS | 70 dbFS | 70 dbFS |
В± DNL (Diff. Non-Linearity) (LSB) | 0.95 | 0.95 | 0.95 | 0.95 | 0.95 | 0.95 |
В± INL (Integral Non-Linearity) (LSB) | 1 | 1 | 1 | 1 | 1 | 1 |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: ISL267450 (6)
- Data Converters > Precision A/D Converters > SAR A/D Converters
