Datasheet Intersil ISL26329 — Даташит
Производитель | Intersil |
Серия | ISL26329 |
12-разрядные АЦП с низким энергопотреблением, скоростью 250 кSPS, несимметричными и дифференциальными входами и несколькими входными каналами
ISL26320, ISL26321, ISL26322, ISL26323, ISL26324, ISL26325, ISL26329 Datasheet
PDF, 1.3 Мб, Версия: 19-10-2017
![]() 23 предложений от 11 поставщиков , ISL26329FVZ 12-bit, 250ksps, 8-Channel, Single-ended SAR ADC HT SUSA CODE:8542390000 | |||
ISL26329FVZ-T Renesas | 200 ₽ | ||
ISL26329FVZ-T Intersil | 291 ₽ | ||
ISL26329FVZ-T Intersil | 369 ₽ |
ISL26329FVZ | ISL26329FVZ-T | ISL26329FVZ-T7A | |
N | 1 | 2 | 3 |
Корпус | 16 Ld TSSOP | 16 Ld TSSOP T+R | 16 Ld TSSOP T+R |
Parameters / Models | ISL26329FVZ | ISL26329FVZ-T | ISL26329FVZ-T7A |
± DNL (Diff. Non-Linearity) (LSB) | 0.7 | 0.7 | 0.7 |
± INL (Integral Non-Linearity) (LSB) | 0.7 | 0.7 | 0.7 |
Analog Supply Voltage (max) (V) | 5.25 V | 5.25 V | 5.25 V |
Analog Supply Voltage (min) (V) | 2.7 V | 2.7 V | 2.7 V |
Количество каналов | 8 | 8 | 8 |
Description | 12-bit, 250kSPS Low-power ADCs with Single-ended and Differential Inputs and Multiple Input Channels | 12-bit, 250kSPS Low-power ADCs with Single-ended and Differential Inputs and Multiple Input Channels | 12-bit, 250kSPS Low-power ADCs with Single-ended and Differential Inputs and Multiple Input Channels |
Max Conv Rate (kSPS) | 250 | 250 | 250 |
Рабочий диапазон температур | от -40 до 125 | от -40 до 125 | от -40 до 125 |
Peak Temp | 260°C | 260°C | 260°C |
Power Consumption | 15 mW | 15 mW | 15 mW |
Qualification Level | Standard | Standard | Standard |
Разрешение | 12 | 12 | 12 |
SFDR | 96 dB | 96 dB | 96 dB |
SINAD | 73.1 dbFS | 73.1 dbFS | 73.1 dbFS |
В± DNL (Diff. Non-Linearity) (LSB) | 0.7 | 0.7 | 0.7 |
В± INL (Integral Non-Linearity) (LSB) | 0.7 | 0.7 | 0.7 |
ISL26320 ISL26321 ISL26322 ISL26323 ISL26324 ISL26325
Серия: ISL26329 (3)
- Data Converters > Precision A/D Converters > SAR A/D Converters
