Datasheet Intersil ICL3222E — Даташит
| Производитель | Intersil |
| Серия | ICL3222E |
В±15kV ESD Protected, +3V to +5.5V, 1ВµA, 250kbps, RS-232 Transmitters/Receivers
ICL3221E, ICL3222E, ICL3223E, ICL3232E, ICL3241E, ICL3243E Datasheet
PDF, 1.4 Мб, Версия: 2017-10-27
| ICL3222ECA | ICL3222ECA-T | ICL3222ECAZ | ICL3222ECAZ-T | ICL3222ECB | ICL3222ECB-T | ICL3222ECP | ICL3222ECV | ICL3222ECV-T | ICL3222ECVZ | ICL3222ECVZ-T | ICL3222EIA | ICL3222EIA-T | ICL3222EIAZ | ICL3222EIAZ-T | ICL3222EIB | ICL3222EIB-T | ICL3222EIBZ | ICL3222EIBZ-T | ICL3222EIV | ICL3222EIV-T | ICL3222EIVZ | ICL3222EIVZ-T | |
| N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | 19 | 20 | 21 | 22 | 23 |
| Корпус | 20 Ld SSOP | 20 Ld SSOP T+R | 20 Ld SSOP | 20 Ld SSOP T+R | 18 Ld SOIC | 18 Ld SOIC T+R | 18 Ld PDIP | 20 Ld TSSOP | 20 Ld TSSOP T+R | 20 Ld TSSOP | 20 Ld TSSOP T+R | 20 Ld SSOP | 20 Ld SSOP T+R | 20 Ld SSOP | 20 Ld SSOP T+R | 18 Ld SOIC | 18 Ld SOIC T+R | 18 Ld SOIC | 18 Ld SOIC T+R | 20 Ld TSSOP | 20 Ld TSSOP T+R | 20 Ld TSSOP | 20 Ld TSSOP T+R |
| Parameters / Models | ICL3222ECA | ICL3222ECA-T | ICL3222ECAZ | ICL3222ECAZ-T | ICL3222ECB | ICL3222ECB-T | ICL3222ECP | ICL3222ECV | ICL3222ECV-T | ICL3222ECVZ | ICL3222ECVZ-T | ICL3222EIA | ICL3222EIA-T | ICL3222EIAZ | ICL3222EIAZ-T | ICL3222EIB | ICL3222EIB-T | ICL3222EIBZ | ICL3222EIBZ-T | ICL3222EIV | ICL3222EIV-T | ICL3222EIVZ | ICL3222EIVZ-T |
| # of Rx | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
| # of Tx | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
| Auto Shutdown | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No |
| Cap. Value | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF |
| Скорость передачи данных | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps |
| Description | ?15kV ESD Protected, +3V to +5.5V, 1?A, 250kbps, RS-232 Transmitters/Receivers | ?15kV ESD Protected, +3V to +5.5V, 1?A, 250kbps, RS-232 Transmitters/Receivers | ?15kV ESD Protected, +3V to +5.5V, 1?A, 250kbps, RS-232 Transmitters/Receivers | ?15kV ESD Protected, +3V to +5.5V, 1?A, 250kbps, RS-232 Transmitters/Receivers | ?15kV ESD Protected, +3V to +5.5V, 1?A, 250kbps, RS-232 Transmitters/Receivers | ?15kV ESD Protected, +3V to +5.5V, 1?A, 250kbps, RS-232 Transmitters/Receivers | ?15kV ESD Protected, +3V to +5.5V, 1?A, 250kbps, RS-232 Transmitters/Receivers | ?15kV ESD Protected, +3V to +5.5V, 1?A, 250kbps, RS-232 Transmitters/Receivers | ?15kV ESD Protected, +3V to +5.5V, 1?A, 250kbps, RS-232 Transmitters/Receivers | ?15kV ESD Protected, +3V to +5.5V, 1?A, 250kbps, RS-232 Transmitters/Receivers | ?15kV ESD Protected, +3V to +5.5V, 1?A, 250kbps, RS-232 Transmitters/Receivers | ?15kV ESD Protected, +3V to +5.5V, 1?A, 250kbps, RS-232 Transmitters/Receivers | ?15kV ESD Protected, +3V to +5.5V, 1?A, 250kbps, RS-232 Transmitters/Receivers | ?15kV ESD Protected, +3V to +5.5V, 1?A, 250kbps, RS-232 Transmitters/Receivers | ?15kV ESD Protected, +3V to +5.5V, 1?A, 250kbps, RS-232 Transmitters/Receivers | ?15kV ESD Protected, +3V to +5.5V, 1?A, 250kbps, RS-232 Transmitters/Receivers | ?15kV ESD Protected, +3V to +5.5V, 1?A, 250kbps, RS-232 Transmitters/Receivers | ?15kV ESD Protected, +3V to +5.5V, 1?A, 250kbps, RS-232 Transmitters/Receivers | ?15kV ESD Protected, +3V to +5.5V, 1?A, 250kbps, RS-232 Transmitters/Receivers | ?15kV ESD Protected, +3V to +5.5V, 1?A, 250kbps, RS-232 Transmitters/Receivers | ?15kV ESD Protected, +3V to +5.5V, 1?A, 250kbps, RS-232 Transmitters/Receivers | ?15kV ESD Protected, +3V to +5.5V, 1?A, 250kbps, RS-232 Transmitters/Receivers | ?15kV ESD Protected, +3V to +5.5V, 1?A, 250kbps, RS-232 Transmitters/Receivers |
| High ESD? | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
| IS Disabled | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA |
| IS Enabled | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA |
| Manual Shutdown | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
| Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
| Peak Temp | 240°C | 240°C | 260°C | 260°C | 240°C | 240°C | 240°C | 240°C | 260°C | 260°C | 240°C | 240°C | 260°C | 260°C | 240°C | 240°C | 260°C | 260°C | 240°C | 240°C | 260°C | 260°C | |
| Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
| Rx Disable | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
| VCC (max) | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
| VCC (min) | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V |
| RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
ICL3221E ICL3223E ICL3232E ICL3241E ICL3243E
Серия: ICL3222E (23)
- Interface ICs > RS-485, RS-422 & RS-232 > RS-232
