Datasheet Intersil ICL3221EF — Даташит
Производитель | Intersil |
Серия | ICL3221EF |
В±15kV ESD Protected, +3V, 1ВµA, 250kbps, RS-232 Transmitters/Receivers
![]() 17 предложений от 10 поставщиков ICL3221EFV Extended Ind. temp 125c to -40c RS232 3V 15KV AU | |||
ICL3221EFVZ Renesas | 28 ₽ | ||
ICL3221EFVZ-T Renesas | 84 ₽ | ||
ICL3221EFVZ Intersil | от 180 ₽ | ||
ICL3221EFVZ-T | по запросу |
ICL3221EFVZ | ICL3221EFVZ-T | ICL3221EFVZ-T7A | |
N | 1 | 2 | 3 |
Корпус | 16 Ld TSSOP | 16 Ld TSSOP T+R | 16 Ld TSSOP T+R |
Parameters / Models | ICL3221EFVZ | ICL3221EFVZ-T | ICL3221EFVZ-T7A |
# of Rx | 1 | 1 | 1 |
# of Tx | 1 | 1 | 1 |
Auto Shutdown | Basic | Basic | Basic |
Cap. Value | 0.1 μF | 0.1 μF | 0.1 μF |
Скорость передачи данных | 0.250 Mbps | 0.250 Mbps | 0.250 Mbps |
Description | ?15kV ESD Protected, +3V, 1?A, 250kbps, RS-232 Transmitters/Receivers | ?15kV ESD Protected, +3V, 1?A, 250kbps, RS-232 Transmitters/Receivers | ?15kV ESD Protected, +3V, 1?A, 250kbps, RS-232 Transmitters/Receivers |
High ESD? | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 |
IS Disabled | 1 μA | 1 μA | 1 μA |
IS Enabled | 0.3 mA | 0.3 mA | 0.3 mA |
Manual Shutdown | Yes | Yes | Yes |
Рабочий диапазон температур | от -40 до 125 | от -40 до 125 | от -40 до 125 |
Peak Temp | 260°C | 260°C | 260°C |
Qualification Level | Standard | Standard | Standard |
Rx Disable | Yes | Yes | Yes |
VCC (max) | 3.6 V | 3.6 V | 3.6 V |
VCC (min) | 3 V | 3 V | 3 V |
Серия: ICL3221EF (3)
- Interface ICs > RS-485, RS-422 & RS-232 > RS-232
