Datasheet Intersil ICL3243 — Даташит
Производитель | Intersil |
Серия | ICL3243 |
Ток питания 1 мА, от +3 В до +5,5 В, 250 кбит/с, передатчики/приемники RS-232
ICL3221, ICL3222, ICL3223, ICL3232, ICL3241, ICL3243 Datasheet
PDF, 1.3 Мб, Версия: 2017-11-01
![]() 38 предложений от 27 поставщиков One Microamp Supply-Current, 3V to 5.5V, 250kbps, RS-232 Transmitters/Receivers | IC TXRX 3/5 RS232 FULL 28SSOP | |||
ICL3243CA Renesas | 17 ₽ | ||
ICL3243CV Rochester Electronics | 39 ₽ | ||
ICL3243CAZ-T Intersil | 55 ₽ | ||
ICL3243ECA-57623 Intersil | по запросу |
ICL3243CA | ICL3243CA-T | ICL3243CAZ | ICL3243CAZ-T | ICL3243CB | ICL3243CB-T | ICL3243CBZ | ICL3243CBZ-T | ICL3243CV | ICL3243CV-T | ICL3243CVZ | ICL3243CVZ-T | ICL3243IA | ICL3243IA-T | ICL3243IAZ | ICL3243IAZ-T | |
N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 |
Корпус | 28 Ld SSOP | 28 Ld SSOP T+R | 28 Ld SSOP | 28 Ld SSOP T+R | 28 Ld SOIC | 28 Ld SOIC T+R | 28 Ld SOIC | 28 Ld SOIC T+R | 28 Ld TSSOP | 28 Ld TSSOP T+R | 28 Ld TSSOP | 28 Ld TSSOP T+R | 28 Ld SSOP | 28 Ld SSOP T+R | 28 Ld SSOP | 28 Ld SSOP T+R |
Parameters / Models | ICL3243CA | ICL3243CA-T | ICL3243CAZ | ICL3243CAZ-T | ICL3243CB | ICL3243CB-T | ICL3243CBZ | ICL3243CBZ-T | ICL3243CV | ICL3243CV-T | ICL3243CVZ | ICL3243CVZ-T | ICL3243IA | ICL3243IA-T | ICL3243IAZ | ICL3243IAZ-T |
# of Rx | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 |
# of Tx | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 |
Auto Shutdown | Basic | Basic | Basic | Basic | Basic | Basic | Basic | Basic | Basic | Basic | Basic | Basic | Basic | Basic | Basic | Basic |
Cap. Value | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF |
Скорость передачи данных | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps |
Description | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers |
High ESD? | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No |
IS Disabled | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA |
IS Enabled | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA |
Manual Shutdown | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Peak Temp | 240°C | 240°C | 260°C | 260°C | 240°C | 240°C | 260°C | 260°C | 240°C | 240°C | 260°C | 260°C | 240°C | 240°C | 260°C | 260°C |
Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
Rx Disable | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No |
VCC (max) | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
VCC (min) | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
ICL3221 ICL3222 ICL3223 ICL3232 ICL3241
Серия: ICL3243 (16)
- Interface ICs > RS-485, RS-422 & RS-232 > RS-232
