Datasheet Intersil HIN202 — Даташит
Производитель | Intersil |
Серия | HIN202 |
+5V Powered RS-232 Transmitters/Receivers with 0.1ВµF External Capacitors
HIN202, HIN206, HIN207, HIN208, HIN211, HIN213 Datasheet
PDF, 977 Кб, Версия: 2017-10-26
![]() 40 предложений от 27 поставщиков IC: интерфейс; трансивер; full duplex,RS232; 120кбит/с; SO16-W | |||
HIN202EIA Harris | 35 ₽ | ||
HIN202ECB-T Intersil | 66 ₽ | ||
HIN202ACBN-T Intersil | по запросу | ||
HIN202E1B Intersil | по запросу |
HIN202CB | HIN202CB-T | HIN202CBN | HIN202CBN-T | HIN202CBNZ | HIN202CBNZ-T | HIN202CBZ | HIN202CBZ-T | HIN202CP | HIN202CPZ | HIN202IB | HIN202IBN | HIN202IBN-T | HIN202IBNZ | HIN202IBNZ-T | HIN202IBZ | |
N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 |
Корпус | 16 Ld SOIC | 16 Ld SOIC T+R | 16 Ld SOIC | 16 Ld SOIC T+R | 16 Ld SOIC | 16 Ld SOIC T+R | 16 Ld SOIC | 16 Ld SOIC T+R | 16 Ld PDIP | 16 Ld PDIP | 16 Ld SOIC | 16 Ld SOIC | 16 Ld SOIC T+R | 16 Ld SOIC | 16 Ld SOIC T+R | 16 Ld SOIC |
Parameters / Models | HIN202CB | HIN202CB-T | HIN202CBN | HIN202CBN-T | HIN202CBNZ | HIN202CBNZ-T | HIN202CBZ | HIN202CBZ-T | HIN202CP | HIN202CPZ | HIN202IB | HIN202IBN | HIN202IBN-T | HIN202IBNZ | HIN202IBNZ-T | HIN202IBZ |
# of Rx | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
# of Tx | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Auto Shutdown | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No |
Cap. Value | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF |
Скорость передачи данных | 0.12 Mbps | 0.12 Mbps | 0.12 Mbps | 0.12 Mbps | 0.12 Mbps | 0.12 Mbps | 0.12 Mbps | 0.12 Mbps | 0.12 Mbps | 0.12 Mbps | 0.12 Mbps | 0.12 Mbps | 0.12 Mbps | 0.12 Mbps | 0.12 Mbps | 0.12 Mbps |
Description | +5V Powered RS-232 Transmitters/Receivers with 0.1?F External Capacitors | +5V Powered RS-232 Transmitters/Receivers with 0.1?F External Capacitors | +5V Powered RS-232 Transmitters/Receivers with 0.1?F External Capacitors | +5V Powered RS-232 Transmitters/Receivers with 0.1?F External Capacitors | +5V Powered RS-232 Transmitters/Receivers with 0.1?F External Capacitors | +5V Powered RS-232 Transmitters/Receivers with 0.1?F External Capacitors | +5V Powered RS-232 Transmitters/Receivers with 0.1?F External Capacitors | +5V Powered RS-232 Transmitters/Receivers with 0.1?F External Capacitors | +5V Powered RS-232 Transmitters/Receivers with 0.1?F External Capacitors | +5V Powered RS-232 Transmitters/Receivers with 0.1?F External Capacitors | +5V Powered RS-232 Transmitters/Receivers with 0.1?F External Capacitors | +5V Powered RS-232 Transmitters/Receivers with 0.1?F External Capacitors | +5V Powered RS-232 Transmitters/Receivers with 0.1?F External Capacitors | +5V Powered RS-232 Transmitters/Receivers with 0.1?F External Capacitors | +5V Powered RS-232 Transmitters/Receivers with 0.1?F External Capacitors | +5V Powered RS-232 Transmitters/Receivers with 0.1?F External Capacitors |
High ESD? | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No |
IS Disabled | N/A μA | N/A μA | N/A μA | N/A μA | N/A μA | N/A μA | N/A μA | N/A μA | N/A μA | N/A μA | N/A μA | N/A μA | N/A μA | N/A μA | N/A μA | N/A μA |
IS Enabled | 8 mA | 8 mA | 8 mA | 8 mA | 8 mA | 8 mA | 8 mA | 8 mA | 8 mA | 8 mA | 8 mA | 8 mA | 8 mA | 8 mA | 8 mA | 8 mA |
Manual Shutdown | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Peak Temp | 240°C | 240°C | 240°C | 240°C | 260°C | 260°C | 260°C | 260°C | 240°C | 240°C | 240°C | 260°C | 260°C | 260°C | ||
Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
Rx Disable | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No |
VCC (max) | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
VCC (min) | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: HIN202 (16)
- Interface ICs > RS-485, RS-422 & RS-232 > RS-232
