Datasheet Intersil ICL3241 — Даташит
| Производитель | Intersil |
| Серия | ICL3241 |
Ток питания 1 мА, от +3 В до +5,5 В, 250 кбит/с, передатчики/приемники RS-232
ICL3221, ICL3222, ICL3223, ICL3232, ICL3241, ICL3243 Datasheet
PDF, 1.3 Мб, Версия: 2017-11-01
Купить ICL3241 на РадиоЛоцман.Цены — от 16 до 270 ₽34 предложений от 26 поставщиков Интегральные микросхемы Интерфейс - Драйверы, Приемники, Трансиверы | |||
| ICL3241CV Renesas | 179 ₽ | ||
| ICL3241CA-T Intersil | по запросу | ||
| ICL3241ECAZ-T Intersil | по запросу | ||
| ICL3241EIR Intersil | по запросу | ||
| ICL3241CA | ICL3241CA-T | ICL3241CAZ | ICL3241CAZ-T | ICL3241CB | ICL3241CB-T | ICL3241CBZ | ICL3241CBZ-T | ICL3241CV | ICL3241CV-T | ICL3241CVZ | ICL3241CVZ-T | ICL3241IA | ICL3241IA-T | ICL3241IAZ | ICL3241IAZ-T | ICL3241IB | ICL3241IB-T | ICL3241IBZ | ICL3241IBZ-T | ICL3241IV | ICL3241IV-T | ICL3241IVZ | ICL3241IVZ-T | |
| N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | 19 | 20 | 21 | 22 | 23 | 24 |
| Корпус | 28 Ld SSOP | 28 Ld SSOP T+R | 28 Ld SSOP | 28 Ld SSOP T+R | 28 Ld SOIC | 28 Ld SOIC T+R | 28 Ld SOIC | 28 Ld SOIC T+R | 28 Ld TSSOP | 28 Ld TSSOP T+R | 28 Ld TSSOP | 28 Ld TSSOP T+R | 28 Ld SSOP | 28 Ld SSOP T+R | 28 Ld SSOP | 28 Ld SSOP T+R | 28 Ld SOIC | 28 Ld SOIC T+R | 28 Ld SOIC | 28 Ld SOIC T+R | 28 Ld TSSOP | 28 Ld TSSOP T+R | 28 Ld TSSOP | 28 Ld TSSOP T+R |
| Parameters / Models | ICL3241CA | ICL3241CA-T | ICL3241CAZ | ICL3241CAZ-T | ICL3241CB | ICL3241CB-T | ICL3241CBZ | ICL3241CBZ-T | ICL3241CV | ICL3241CV-T | ICL3241CVZ | ICL3241CVZ-T | ICL3241IA | ICL3241IA-T | ICL3241IAZ | ICL3241IAZ-T | ICL3241IB | ICL3241IB-T | ICL3241IBZ | ICL3241IBZ-T | ICL3241IV | ICL3241IV-T | ICL3241IVZ | ICL3241IVZ-T |
| # of Rx | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 |
| # of Tx | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 |
| Auto Shutdown | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No |
| Cap. Value | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF |
| Скорость передачи данных | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps |
| Description | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers | 1mA Supply-Current, +3V to +5.5V, 250kbps, RS-232 Transmitters/Receivers |
| High ESD? | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No |
| IS Disabled | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA | 1 μA |
| IS Enabled | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA |
| Manual Shutdown | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
| Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
| Peak Temp | 240°C | 240°C | 260°C | 260°C | 240°C | 240°C | 260°C | 260°C | 240°C | 240°C | 260°C | 260°C | 240°C | 240°C | 260°C | 260°C | 240°C | 240°C | 260°C | 260°C | 240°C | 240°C | 260°C | 260°C |
| Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
| Rx Disable | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
| VCC (max) | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
| VCC (min) | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V |
| RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
ICL3221 ICL3222 ICL3223 ICL3232 ICL3243
Серия: ICL3241 (24)
- Interface ICs > RS-485, RS-422 & RS-232 > RS-232
