Datasheet Intersil ICL3238E — Даташит
Производитель | Intersil |
Серия | ICL3238E |
В±15kV ESD Protected, 5-Tx, 3-Rx, 250kbps, RS-232 Transceiver with Enhanced Automatic Powerdown
![]() 34 предложений от 24 поставщиков Интегральные микросхемы Интерфейс - Драйверы, Приемники, Трансиверы | |||
ICL3238IA-T Intersil | по запросу | ||
ICL3238EIAZ-T Intersil | по запросу | ||
ICL3238CAZ Intersil | по запросу | ||
ICL3238CAZ Renesas | по запросу |
ICL3238ECA | ICL3238ECA-T | ICL3238ECAZ | ICL3238ECAZ-T | ICL3238EIA | ICL3238EIA-T | ICL3238EIAZ | ICL3238EIAZ-T | ICL3238EIV | ICL3238EIV-T | ICL3238EIVZ | ICL3238EIVZ-T | |
N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 |
Корпус | 28 Ld SSOP | 28 Ld SSOP T+R | 28 Ld SSOP | 28 Ld SSOP T+R | 28 Ld SSOP | 28 Ld SSOP T+R | 28 Ld SSOP | 28 Ld SSOP T+R | 28 Ld TSSOP | 28 Ld TSSOP T+R | 28 Ld TSSOP | 28 Ld TSSOP T+R |
Parameters / Models | ICL3238ECA | ICL3238ECA-T | ICL3238ECAZ | ICL3238ECAZ-T | ICL3238EIA | ICL3238EIA-T | ICL3238EIAZ | ICL3238EIAZ-T | ICL3238EIV | ICL3238EIV-T | ICL3238EIVZ | ICL3238EIVZ-T |
# of Rx | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 |
# of Tx | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 |
Auto Shutdown | Enhanced | Enhanced | Enhanced | Enhanced | Enhanced | Enhanced | Enhanced | Enhanced | Enhanced | Enhanced | Enhanced | Enhanced |
Cap. Value | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF |
Скорость передачи данных | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps |
Description | ?15kV ESD Protected, 5-Tx, 3-Rx, 250kbps, RS-232 Transceiver with Enhanced Automatic Powerdown | ?15kV ESD Protected, 5-Tx, 3-Rx, 250kbps, RS-232 Transceiver with Enhanced Automatic Powerdown | ?15kV ESD Protected, 5-Tx, 3-Rx, 250kbps, RS-232 Transceiver with Enhanced Automatic Powerdown | ?15kV ESD Protected, 5-Tx, 3-Rx, 250kbps, RS-232 Transceiver with Enhanced Automatic Powerdown | ?15kV ESD Protected, 5-Tx, 3-Rx, 250kbps, RS-232 Transceiver with Enhanced Automatic Powerdown | ?15kV ESD Protected, 5-Tx, 3-Rx, 250kbps, RS-232 Transceiver with Enhanced Automatic Powerdown | ?15kV ESD Protected, 5-Tx, 3-Rx, 250kbps, RS-232 Transceiver with Enhanced Automatic Powerdown | ?15kV ESD Protected, 5-Tx, 3-Rx, 250kbps, RS-232 Transceiver with Enhanced Automatic Powerdown | ?15kV ESD Protected, 5-Tx, 3-Rx, 250kbps, RS-232 Transceiver with Enhanced Automatic Powerdown | ?15kV ESD Protected, 5-Tx, 3-Rx, 250kbps, RS-232 Transceiver with Enhanced Automatic Powerdown | ?15kV ESD Protected, 5-Tx, 3-Rx, 250kbps, RS-232 Transceiver with Enhanced Automatic Powerdown | ?15kV ESD Protected, 5-Tx, 3-Rx, 250kbps, RS-232 Transceiver with Enhanced Automatic Powerdown |
High ESD? | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
IS Disabled | 0.01 μA | 0.01 μA | 0.01 μA | 0.01 μA | 0.01 μA | 0.01 μA | 0.01 μA | 0.01 μA | 0.01 μA | 0.01 μA | 0.01 μA | 0.01 μA |
IS Enabled | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA | 0.3 mA |
Manual Shutdown | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Peak Temp | 240°C | 240°C | 260°C | 260°C | 240°C | 240°C | 260°C | 260°C | 240°C | 240°C | 260°C | 260°C |
Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
Rx Disable | No | No | No | No | No | No | No | No | No | No | No | No |
VCC (max) | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
VCC (min) | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: ICL3238E (12)
- Interface ICs > RS-485, RS-422 & RS-232 > RS-232
