Datasheet Intersil HIN213 — Даташит
| Производитель | Intersil |
| Серия | HIN213 |
+5V Powered RS-232 Transmitters/Receivers with 0.1ВµF External Capacitors
HIN202, HIN206, HIN207, HIN208, HIN211, HIN213 Datasheet
PDF, 977 Кб, Версия: 2017-10-26
| HIN213CA | HIN213CA-T | HIN213CAZ | HIN213CAZ-T | |
| N | 1 | 2 | 3 | 4 |
| Корпус | 28 Ld SSOP | 28 Ld SSOP T+R | 28 Ld SSOP | 28 Ld SSOP T+R |
| Parameters / Models | HIN213CA | HIN213CA-T | HIN213CAZ | HIN213CAZ-T |
| # of Rx | 5 | 5 | 5 | 5 |
| # of Tx | 4 | 4 | 4 | 4 |
| Auto Shutdown | No | No | No | No |
| Cap. Value | 0.1 μF | 0.1 μF | 0.1 μF | 0.1 μF |
| Скорость передачи данных | 0.12 Mbps | 0.12 Mbps | 0.12 Mbps | 0.12 Mbps |
| Description | +5V Powered RS-232 Transmitters/Receivers with 0.1?F External Capacitors | +5V Powered RS-232 Transmitters/Receivers with 0.1?F External Capacitors | +5V Powered RS-232 Transmitters/Receivers with 0.1?F External Capacitors | +5V Powered RS-232 Transmitters/Receivers with 0.1?F External Capacitors |
| High ESD? | No | No | No | No |
| IS Disabled | 15 μA | 15 μA | 15 μA | 15 μA |
| IS Enabled | 11 mA | 11 mA | 11 mA | 11 mA |
| Manual Shutdown | Yes | Yes | Yes | Yes |
| Рабочий диапазон температур | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 |
| Peak Temp | 240°C | 240°C | 260°C | 260°C |
| Qualification Level | Standard | Standard | Standard | Standard |
| Rx Disable | Yes | Yes | Yes | Yes |
| VCC (max) | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
| VCC (min) | 4.5 V | 4.5 V | 4.5 V | 4.5 V |
| RoHS | Совместим | Совместим |
Серия: HIN213 (4)
- Interface ICs > RS-485, RS-422 & RS-232 > RS-232
