Datasheet Intersil ICL232 — Даташит
Производитель | Intersil |
Серия | ICL232 |
Питание +5 В, двойной передатчик/приемник RS-232
![]() 39 предложений от 27 поставщиков IC: интерфейс; трансивер; full duplex,RS232; SO16-W; 4,5÷5,5ВDC | |||
ICL232CPE Renesas | 36 ₽ | ||
ICL232(SMD,ST232CDR,2.5K/R)'01 Intersil | по запросу | ||
ICL232CPE Intersil | по запросу | ||
ICL232IPE Intersil | по запросу |
ICL232CBE | ICL232CBET | ICL232CBEZ | ICL232CBEZT | ICL232CPE | ICL232IBE | ICL232IBET | ICL232IPE | ICL232MJE | |
N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 |
Корпус | 16 Ld SOIC | 16 Ld SOIC T+R | 16 Ld SOIC | 16 Ld SOIC T+R | 16 Ld PDIP | 16 Ld SOIC | 16 Ld SOIC T+R | 16 Ld PDIP | 16 Ld CERDIP |
Parameters / Models | ICL232CBE | ICL232CBET | ICL232CBEZ | ICL232CBEZT | ICL232CPE | ICL232IBE | ICL232IBET | ICL232IPE | ICL232MJE |
# of Rx | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
# of Tx | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Auto Shutdown | No | No | No | No | No | No | No | No | No |
Cap. Value | 1 μF | 1 μF | 1 μF | 1 μF | 1 μF | 1 μF | 1 μF | 1 μF | 1 μF |
Скорость передачи данных | 0.12 Mbps | 0.12 Mbps | 0.12 Mbps | 0.12 Mbps | 0.12 Mbps | 0.12 Mbps | 0.12 Mbps | 0.12 Mbps | 0.12 Mbps |
Description | +5V Powered, Dual RS-232 Transmitter/Receiver | +5V Powered, Dual RS-232 Transmitter/Receiver | +5V Powered, Dual RS-232 Transmitter/Receiver | +5V Powered, Dual RS-232 Transmitter/Receiver | +5V Powered, Dual RS-232 Transmitter/Receiver | +5V Powered, Dual RS-232 Transmitter/Receiver | +5V Powered, Dual RS-232 Transmitter/Receiver | +5V Powered, Dual RS-232 Transmitter/Receiver | +5V Powered, Dual RS-232 Transmitter/Receiver |
High ESD? | No | No | No | No | No | No | No | No | No |
IS Disabled | N/A μA | N/A μA | N/A μA | N/A μA | N/A μA | N/A μA | N/A μA | N/A μA | N/A μA |
IS Enabled | 5 mA | 5 mA | 5 mA | 5 mA | 5 mA | 5 mA | 5 mA | 5 mA | 5 mA |
Manual Shutdown | No | No | No | No | No | No | No | No | No |
Рабочий диапазон температур | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 |
Peak Temp | 240°C | 240°C | 260°C | 260°C | 240°C | 240°C | |||
Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
Rx Disable | No | No | No | No | No | No | No | No | No |
VCC (max) | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
VCC (min) | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V |
Серия: ICL232 (9)
- Interface ICs > RS-485, RS-422 & RS-232 > RS-232
