Datasheet Intersil ISL32172E — Даташит
Производитель | Intersil |
Серия | ISL32172E |
Quad, В±16.5kV ESD Protected, 3.0V to 5.5V, Low Power, RS-422 Transmitters
ISL32172E, ISL32272E, ISL32372E, ISL32174E, ISL32274E, ISL32374E, ISL32179E Datasheet
PDF, 1.4 Мб, Версия: 2017-10-10
![]() 48 предложений от 25 поставщиков Интегральные микросхемы Интерфейс - Драйверы, Приемники, Трансиверы | |||
ISL32172EFVZ-T Intersil | от 108 ₽ | ||
ISL32172EFBZ-T Intersil | по запросу | ||
ISL32172EIBZ-T Intersil | по запросу | ||
ISL32172EFVZ-T Intersil | по запросу |
ISL32172EFBZ | ISL32172EFBZ-T | ISL32172EFVZ | ISL32172EFVZ-T | ISL32172EIBZ | ISL32172EIBZ-T | ISL32172EIVZ | ISL32172EIVZ-T | |
N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 |
Корпус | 16 Ld SOIC | 16 Ld SOIC T+R | 16 Ld TSSOP | 16 Ld TSSOP T+R | 16 Ld SOIC | 16 Ld SOIC T+R | 16 Ld TSSOP | 16 Ld TSSOP T+R |
Parameters / Models | ISL32172EFBZ | ISL32172EFBZ-T | ISL32172EFVZ | ISL32172EFVZ-T | ISL32172EIBZ | ISL32172EIBZ-T | ISL32172EIVZ | ISL32172EIVZ-T |
# of Tx | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 |
Скорость передачи данных | 32 Mbps | 32 Mbps | 32 Mbps | 32 Mbps | 32 Mbps | 32 Mbps | 32 Mbps | 32 Mbps |
Description | Quad, ?16.5kV ESD Protected, 3.0V to 5.5V, Low Power, RS-422 Transmitters | Quad, ?16.5kV ESD Protected, 3.0V to 5.5V, Low Power, RS-422 Transmitters | Quad, ?16.5kV ESD Protected, 3.0V to 5.5V, Low Power, RS-422 Transmitters | Quad, ?16.5kV ESD Protected, 3.0V to 5.5V, Low Power, RS-422 Transmitters | Quad, ?16.5kV ESD Protected, 3.0V to 5.5V, Low Power, RS-422 Transmitters | Quad, ?16.5kV ESD Protected, 3.0V to 5.5V, Low Power, RS-422 Transmitters | Quad, ?16.5kV ESD Protected, 3.0V to 5.5V, Low Power, RS-422 Transmitters | Quad, ?16.5kV ESD Protected, 3.0V to 5.5V, Low Power, RS-422 Transmitters |
Devices Allowed on Bus | 256 | 256 | 256 | 256 | 256 | 256 | 256 | 256 |
Half/Full Duplex | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A |
High ESD? | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 |
Hot Plug | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
IS Enabled/Disabled | 600 μA | 600 μA | 600 μA | 600 μA | 600 μA | 600 μA | 600 μA | 600 μA |
Key Feature | Ruggedized | Ruggedized | Ruggedized | Ruggedized | Ruggedized | Ruggedized | Ruggedized | Ruggedized |
Рабочий диапазон температур | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 |
Peak Temp | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C |
Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
SHDN ICC | N/A μA | N/A μA | N/A μA | N/A μA | N/A μA | N/A μA | N/A μA | N/A μA |
Slew Rate Limited | No | No | No | No | No | No | No | No |
Tx/Rx Enable | Yes - Group Enables | Yes - Group Enables | Yes - Group Enables | Yes - Group Enables | Yes - Group Enables | Yes - Group Enables | Yes - Group Enables | Yes - Group Enables |
VCC (max) | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
VCC (min) | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V |
VL Pin | No | No | No | No | No | No | No | No |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: ISL32172E (8)
- Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422
