Datasheet Intersil ISL32601E — Даташит
ПроизводительIntersil
СерияISL32601E
1.8V to 3.3V, Micro-Power, В±15kV ESD, +125В°C, Slew Rate Limited, RS-485/RS-422 Transceivers
ISL32600E, ISL32601E, ISL32602E, ISL32603E Datasheet
PDF, 1.2 Мб, Версия: 2014-12-15
34 предложений от 19 поставщиков
Элитан
ISL32601EFBZ
Renesas
368 ₽
ISL32601EFBZ
Renesas
от 445 ₽
Hi-Tech Circuit Group
ISL32601EFUZ-T
ISL32601EFUZ-T
ISL32601EFBZISL32601EFBZ-TISL32601EFBZ-T7AISL32601EFUZISL32601EFUZ-TISL32601EFUZ-T7A
N123456
Корпус8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC T+R8 Ld MSOP8 Ld MSOP T+R8 Ld MSOP T+R
Parameters / ModelsISL32601EFBZISL32601EFBZ-TISL32601EFBZ-T7AISL32601EFUZISL32601EFUZ-TISL32601EFUZ-T7A
# of Rx111111
# of Tx111111
Скорость передачи данных0.256 Mbps0.256 Mbps0.256 Mbps0.256 Mbps0.256 Mbps0.256 Mbps
Description1.8V to 3.3V, Micro-Power, ?15kV ESD, +125?C, Slew Rate Limited, RS-485/RS-422 Transceivers1.8V to 3.3V, Micro-Power, ?15kV ESD, +125?C, Slew Rate Limited, RS-485/RS-422 Transceivers1.8V to 3.3V, Micro-Power, ?15kV ESD, +125?C, Slew Rate Limited, RS-485/RS-422 Transceivers1.8V to 3.3V, Micro-Power, ?15kV ESD, +125?C, Slew Rate Limited, RS-485/RS-422 Transceivers1.8V to 3.3V, Micro-Power, ?15kV ESD, +125?C, Slew Rate Limited, RS-485/RS-422 Transceivers1.8V to 3.3V, Micro-Power, ?15kV ESD, +125?C, Slew Rate Limited, RS-485/RS-422 Transceivers
Devices Allowed on Bus256256256256256256
Half/Full DuplexHalfHalfHalfHalfHalfHalf
High ESD?Yes-IEC61000Yes-IEC61000Yes-IEC61000Yes-IEC61000Yes-IEC61000Yes-IEC61000
Hot PlugYesYesYesYesYesYes
IS Enabled/Disabled60 μA60 μA60 μA60 μA60 μA60 μA
Key FeatureLow PowerLow PowerLow PowerLow PowerLow PowerLow Power
Рабочий диапазон температурот -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125
Peak Temp260°C260°C260°C260°C260°C260°C
Qualification LevelStandardStandardStandardStandardStandardStandard
SHDN ICC.01 μA.01 μA.01 μA.01 μA.01 μA.01 μA
Slew Rate LimitedYesYesYesYesYesYes
Tx/Rx EnableYesYesYesYesYesYes
VCC (max)3.6 V3.6 V3.6 V3.6 V3.6 V3.6 V
VCC (min)2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V
VL PinNoNoNoNoNoNo
RoHSСовместимСовместимСовместимСовместимСовместимСовместим
ISL32600E ISL32602E ISL32603E
  • Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422
На английском языке: Datasheet Intersil ISL32601E
