Datasheet Intersil ISL32611E — Даташит
Производитель | Intersil |
Серия | ISL32611E |
В±16.5kV IEC ESD , 1.8V, Micro Power, RS-485/RS-422 Differential Receiver with active low Rx enable
![]() 13 предложений от 13 поставщиков Интегральные микросхемы Интерфейс - Драйверы, Приемники, Трансиверы | |||
ISL32611EFHZ-T Intersil | 79 ₽ | ||
ISL32611EFHZ-T | 106 ₽ | ||
ISL32611EFHZ-T Renesas | 268 ₽ | ||
ISL32611EFHZ-T Intersil | 300 ₽ |
ISL32611EFHZ-T | ISL32611EFHZ-T7A | |
N | 1 | 2 |
Корпус | 6 Ld SOT T+R | 6 Ld SOT T+R |
Parameters / Models | ISL32611EFHZ-T | ISL32611EFHZ-T7A |
# of Rx | 1 | 1 |
Скорость передачи данных | 0.256 Mbps | 0.256 Mbps |
Description | ?16.5kV IEC ESD , 1.8V, Micro Power, RS-485/RS-422 Differential Receiver with active low Rx enable | ?16.5kV IEC ESD , 1.8V, Micro Power, RS-485/RS-422 Differential Receiver with active low Rx enable |
Devices Allowed on Bus | 256 | 256 |
Half/Full Duplex | N/A | N/A |
High ESD? | Yes-IEC61000 | Yes-IEC61000 |
Hot Plug | No | No |
IS Enabled/Disabled | 85 μA | 85 μA |
Key Feature | Low Power | Low Power |
Рабочий диапазон температур | от -40 до 125 | от -40 до 125 |
Peak Temp | 260°C | 260°C |
Qualification Level | Standard | Standard |
SHDN ICC | .002 μA | .002 μA |
Slew Rate Limited | N/A | N/A |
Tx/Rx Enable | Yes - Active Low | Yes - Active Low |
VCC (max) | 3.6 V | 3.6 V |
VCC (min) | 1.8 V | 1.8 V |
VL Pin | No | No |
Серия: ISL32611E (2)
- Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422
