Линейка продуктов KEEN SIDE
Datasheet Intersil ISL8483E — Даташит
ПроизводительIntersil
СерияISL8483E
ESD Protected to В±15kV, 5V, Low Power, Slew Rate Limited, RS-485/RS-422 Transceivers
ISL8483E, ISL8485E Datasheet
PDF, 1.2 Мб, Версия: 2017-08-31
59 предложений от 27 поставщиков
ISL8483IP
51 ₽
ISL8483IP
Intersil
51 ₽
ISL8483CPZ (ISL8483CPZ  )
Intersil
TradeElectronics
ISL8483EIBZ-T
Intersil
ISL8483ECPZISL8483EIBISL8483EIB-TISL8483EIBZISL8483EIBZ-TISL8483EIPISL8483EIPZ
N1234567
Корпус8 Ld PDIP8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC8 Ld SOIC T+R8 Ld PDIP8 Ld PDIP
Parameters / ModelsISL8483ECPZISL8483EIBISL8483EIB-TISL8483EIBZISL8483EIBZ-TISL8483EIPISL8483EIPZ
# of Rx1111111
# of Tx1111111
Скорость передачи данных0.25 Mbps0.25 Mbps0.25 Mbps0.25 Mbps0.25 Mbps0.25 Mbps0.25 Mbps
DescriptionESD Protected to ?15kV, 5V, Low Power, Slew Rate Limited, RS-485/RS-422 TransceiversESD Protected to ?15kV, 5V, Low Power, Slew Rate Limited, RS-485/RS-422 TransceiversESD Protected to ?15kV, 5V, Low Power, Slew Rate Limited, RS-485/RS-422 TransceiversESD Protected to ?15kV, 5V, Low Power, Slew Rate Limited, RS-485/RS-422 TransceiversESD Protected to ?15kV, 5V, Low Power, Slew Rate Limited, RS-485/RS-422 TransceiversESD Protected to ?15kV, 5V, Low Power, Slew Rate Limited, RS-485/RS-422 TransceiversESD Protected to ?15kV, 5V, Low Power, Slew Rate Limited, RS-485/RS-422 Transceivers
Devices Allowed on Bus32323232323232
Half/Full DuplexHalfHalfHalfHalfHalfHalfHalf
High ESD?YesYesYesYesYesYesYes
Hot PlugNoNoNoNoNoNoNo
IS Enabled/Disabled470/160 μA470/160 μA470/160 μA470/160 μA470/160 μA470/160 μA470/160 μA
Key FeatureLow CostLow CostLow CostLow CostLow CostLow CostLow Cost
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Peak Temp240°C240°C260°C260°C
Qualification LevelStandardStandardStandardStandardStandardStandardStandard
SHDN ICC0.001 μA0.001 μA0.001 μA0.001 μA0.001 μA0.001 μA0.001 μA
Slew Rate LimitedYesYesYesYesYesYesYes
Tx/Rx EnableYesYesYesYesYesYesYes
VCC (max)5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V
VCC (min)4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V
VL PinNoNoNoNoNoNoNo
RoHSСовместимСовместимСовместимСовместим
ISL8485E
  • Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422
На английском языке: Datasheet Intersil ISL8483E
