Datasheet Intersil ISL3152E — Даташит
| Производитель | Intersil |
| Серия | ISL3152E |
5 В, дифференциальный приемопередатчик RS-485/RS-422
ISL3150E, ISL3152E, ISL3153E, ISL3155E, ISL3156E, ISL3158E Datasheet
PDF, 1.7 Мб, Версия: 2017-08-31
Купить ISL3152E на РадиоЛоцман.Цены — от 13 до 239 ₽48 предложений от 23 поставщиков Интегральные микросхемы Интерфейс - Драйверы, Приемники, Трансиверы | |||
| ISL3152EIBZ Intersil | 47 ₽ | ||
| ISL3152EIBZ-T Intersil | от 90 ₽ | ||
| ISL3152EIUZ Renesas | от 205 ₽ | ||
| ISL3152EIBZ | по запросу | ||
| ISL3152EIBZ | ISL3152EIBZ-T | ISL3152EIBZ-T7A | ISL3152EIPZ | ISL3152EIUZ | ISL3152EIUZ-T | ISL3152EIUZ-T7A | |
| N | 1 | 2 | 3 | 4 | 5 | 6 | 7 |
| Корпус | 8 Ld SOIC | 8 Ld SOIC T+R | 8 Ld SOIC T+R | 8 Ld PDIP | 8 Ld MSOP | 8 Ld MSOP T+R | 8 Ld MSOP T+R |
| Parameters / Models | ISL3152EIBZ | ISL3152EIBZ-T | ISL3152EIBZ-T7A | ISL3152EIPZ | ISL3152EIUZ | ISL3152EIUZ-T | ISL3152EIUZ-T7A |
| # of Rx | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| # of Tx | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| Скорость передачи данных | 0.115 Mbps | 0.115 Mbps | 0.115 Mbps | 0.115 Mbps | 0.115 Mbps | 0.115 Mbps | 0.115 Mbps |
| Description | 5V, RS-485/RS-422 Differential Transceiver | 5V, RS-485/RS-422 Differential Transceiver | 5V, RS-485/RS-422 Differential Transceiver | 5V, RS-485/RS-422 Differential Transceiver | 5V, RS-485/RS-422 Differential Transceiver | 5V, RS-485/RS-422 Differential Transceiver | 5V, RS-485/RS-422 Differential Transceiver |
| Devices Allowed on Bus | 256 | 256 | 256 | 256 | 256 | 256 | 256 |
| Half/Full Duplex | Half | Half | Half | Half | Half | Half | Half |
| High ESD? | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 |
| Hot Plug | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
| IS Enabled/Disabled | 800/700 μA | 800/700 μA | 800/700 μA | 800/700 μA | 800/700 μA | 800/700 μA | 800/700 μA |
| Key Feature | Ruggedized | Ruggedized | Ruggedized | Ruggedized | Ruggedized | Ruggedized | Ruggedized |
| Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
| Peak Temp | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | |
| Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
| SHDN ICC | 0.07 μA | 0.07 μA | 0.07 μA | 0.07 μA | 0.07 μA | 0.07 μA | 0.07 μA |
| Slew Rate Limited | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
| Tx/Rx Enable | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
| VCC (max) | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
| VCC (min) | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V |
| VL Pin | No | No | No | No | No | No | No |
| RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
ISL3150E ISL3153E ISL3155E ISL3156E ISL3158E
Серия: ISL3152E (7)
- Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422
