Datasheet Intersil ISL81487L — Даташит
ПроизводительIntersil
СерияISL81487L
5V, Half Duplex, 250kbps Slew Rate Limited, В±15kV ESD Protected, RS-485/RS-422 Transceiver
ISL8487E, ISL81487L, ISL81487E Datasheet
PDF, 763 Кб, Версия: 2017-10-23
ИС интерфейса RS-422/RS-485 8LD -40C+85C 15KV HB M5VRS-485 1/8 HI SPE
ISL81487L
Intersil
ISL81487LIBISL81487LIB-TISL81487LIBZISL81487LIBZ-TISL81487LIPISL81487LIPZ
N123456
Корпус8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC8 Ld SOIC T+R8 Ld PDIP8 Ld PDIP
Parameters / ModelsISL81487LIBISL81487LIB-TISL81487LIBZISL81487LIBZ-TISL81487LIPISL81487LIPZ
# of Rx111111
# of Tx111111
Скорость передачи данных0.25 Mbps0.25 Mbps0.25 Mbps0.25 Mbps0.25 Mbps0.25 Mbps
Description5V, Half Duplex, 250kbps Slew Rate Limited, ?15kV ESD Protected, RS-485/RS-422 Transceiver5V, Half Duplex, 250kbps Slew Rate Limited, ?15kV ESD Protected, RS-485/RS-422 Transceiver5V, Half Duplex, 250kbps Slew Rate Limited, ?15kV ESD Protected, RS-485/RS-422 Transceiver5V, Half Duplex, 250kbps Slew Rate Limited, ?15kV ESD Protected, RS-485/RS-422 Transceiver5V, Half Duplex, 250kbps Slew Rate Limited, ?15kV ESD Protected, RS-485/RS-422 Transceiver5V, Half Duplex, 250kbps Slew Rate Limited, ?15kV ESD Protected, RS-485/RS-422 Transceiver
Devices Allowed on Bus256256256256256256
Half/Full DuplexHalfHalfHalfHalfHalfHalf
High ESD?YesYesYesYesYesYes
Hot PlugNoNoNoNoNoNo
IS Enabled/Disabled160/120 μA160/120 μA160/120 μA160/120 μA160/120 μA160/120 μA
Key FeatureLow CostLow CostLow CostLow CostLow CostLow Cost
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Peak Temp240°C240°C260°C260°C
Qualification LevelStandardStandardStandardStandardStandardStandard
SHDN ICC0.001 μA0.001 μA0.001 μA0.001 μA0.001 μA0.001 μA
Slew Rate LimitedYesYesYesYesYesYes
Tx/Rx EnableYesYesYesYesYesYes
VCC (max)5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V
VCC (min)4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V
VL PinNoNoNoNoNoNo
ISL81487E ISL8487E
  • Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422
На английском языке: Datasheet Intersil ISL81487L
