Datasheet Intersil ISL3159E — Даташит
Производитель | Intersil |
Серия | ISL3159E |
В±15kV ESD Protected, +125В°C, 40Mbps, 5V, PROFIBUS, Full Fail-safe, RS-485/RS-422 Transceivers
![]() 39 предложений от 23 поставщиков Интегральные микросхемы Интерфейс - Драйверы, Приемники, Трансиверы | |||
ISL3159EIRZ-T Intersil | 73 ₽ | ||
ISL3159EIUZ-T Renesas | от 203 ₽ | ||
ISL3159EFUZ Intersil | по запросу | ||
ISL3159EFBZ-T Intersil | по запросу |
ISL3159EFBZ | ISL3159EFBZ-T | ISL3159EFBZ-T7A | ISL3159EFRZ | ISL3159EFRZ-T | ISL3159EFRZ-T7A | ISL3159EFUZ | ISL3159EFUZ-T | ISL3159EFUZ-T7A | ISL3159EIBZ | ISL3159EIBZ-T | ISL3159EIBZ-T7A | ISL3159EIRZ | ISL3159EIRZ-T | ISL3159EIRZ-T7A | ISL3159EIUZ | ISL3159EIUZ-T | ISL3159EIUZ-T7A | |
N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 17 | 18 |
Корпус | 8 Ld SOIC | 8 Ld SOIC T+R | 8 Ld SOIC T+R | 10 Ld DFN | 10 Ld DFN T+R | 10 Ld DFN T+R | 8 Ld MSOP | 8 Ld MSOP T+R | 8 Ld MSOP T+R | 8 Ld SOIC | 8 Ld SOIC T+R | 8 Ld SOIC T+R | 10 Ld DFN | 10 Ld DFN T+R | 10 Ld DFN T+R | 8 Ld MSOP | 8 Ld MSOP T+R | 8 Ld MSOP T+R |
Parameters / Models | ISL3159EFBZ | ISL3159EFBZ-T | ISL3159EFBZ-T7A | ISL3159EFRZ | ISL3159EFRZ-T | ISL3159EFRZ-T7A | ISL3159EFUZ | ISL3159EFUZ-T | ISL3159EFUZ-T7A | ISL3159EIBZ | ISL3159EIBZ-T | ISL3159EIBZ-T7A | ISL3159EIRZ | ISL3159EIRZ-T | ISL3159EIRZ-T7A | ISL3159EIUZ | ISL3159EIUZ-T | ISL3159EIUZ-T7A |
# of Rx | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
# of Tx | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Скорость передачи данных | 40 Mbps | 40 Mbps | 40 Mbps | 40 Mbps | 40 Mbps | 40 Mbps | 40 Mbps | 40 Mbps | 40 Mbps | 40 Mbps | 40 Mbps | 40 Mbps | 40 Mbps | 40 Mbps | 40 Mbps | 40 Mbps | 40 Mbps | 40 Mbps |
Description | ?15kV ESD Protected, +125?C, 40Mbps, 5V, PROFIBUS, Full Fail-safe, RS-485/RS-422 Transceivers | ?15kV ESD Protected, +125?C, 40Mbps, 5V, PROFIBUS, Full Fail-safe, RS-485/RS-422 Transceivers | ?15kV ESD Protected, +125?C, 40Mbps, 5V, PROFIBUS, Full Fail-safe, RS-485/RS-422 Transceivers | ?15kV ESD Protected, +125?C, 40Mbps, 5V, PROFIBUS, Full Fail-safe, RS-485/RS-422 Transceivers | ?15kV ESD Protected, +125?C, 40Mbps, 5V, PROFIBUS, Full Fail-safe, RS-485/RS-422 Transceivers | ?15kV ESD Protected, +125?C, 40Mbps, 5V, PROFIBUS, Full Fail-safe, RS-485/RS-422 Transceivers | ?15kV ESD Protected, +125?C, 40Mbps, 5V, PROFIBUS, Full Fail-safe, RS-485/RS-422 Transceivers | ?15kV ESD Protected, +125?C, 40Mbps, 5V, PROFIBUS, Full Fail-safe, RS-485/RS-422 Transceivers | ?15kV ESD Protected, +125?C, 40Mbps, 5V, PROFIBUS, Full Fail-safe, RS-485/RS-422 Transceivers | ?15kV ESD Protected, +125?C, 40Mbps, 5V, PROFIBUS, Full Fail-safe, RS-485/RS-422 Transceivers | ?15kV ESD Protected, +125?C, 40Mbps, 5V, PROFIBUS, Full Fail-safe, RS-485/RS-422 Transceivers | ?15kV ESD Protected, +125?C, 40Mbps, 5V, PROFIBUS, Full Fail-safe, RS-485/RS-422 Transceivers | ?15kV ESD Protected, +125?C, 40Mbps, 5V, PROFIBUS, Full Fail-safe, RS-485/RS-422 Transceivers | ?15kV ESD Protected, +125?C, 40Mbps, 5V, PROFIBUS, Full Fail-safe, RS-485/RS-422 Transceivers | ?15kV ESD Protected, +125?C, 40Mbps, 5V, PROFIBUS, Full Fail-safe, RS-485/RS-422 Transceivers | ?15kV ESD Protected, +125?C, 40Mbps, 5V, PROFIBUS, Full Fail-safe, RS-485/RS-422 Transceivers | ?15kV ESD Protected, +125?C, 40Mbps, 5V, PROFIBUS, Full Fail-safe, RS-485/RS-422 Transceivers | ?15kV ESD Protected, +125?C, 40Mbps, 5V, PROFIBUS, Full Fail-safe, RS-485/RS-422 Transceivers |
Devices Allowed on Bus | 160 | 160 | 160 | 160 | 160 | 160 | 160 | 160 | 160 | 160 | 160 | 160 | 160 | 160 | 160 | 160 | 160 | 160 |
Half/Full Duplex | Half | Half | Half | Half | Half | Half | Half | Half | Half | Half | Half | Half | Half | Half | Half | Half | Half | Half |
High ESD? | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 |
Hot Plug | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
IS Enabled/Disabled | 2600/2600 μA | 2600/2600 μA | 2600/2600 μA | 2600/2600 μA | 2600/2600 μA | 2600/2600 μA | 2600/2600 μA | 2600/2600 μA | 2600/2600 μA | 2600/2600 μA | 2600/2600 μA | 2600/2600 μA | 2600/2600 μA | 2600/2600 μA | 2600/2600 μA | 2600/2600 μA | 2600/2600 μA | 2600/2600 μA |
Key Feature | High Speed | High Speed | High Speed | High Speed | High Speed | High Speed | High Speed | High Speed | High Speed | High Speed | High Speed | High Speed | High Speed | High Speed | High Speed | High Speed | High Speed | High Speed |
Рабочий диапазон температур | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 |
Peak Temp | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C |
Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
Slew Rate Limited | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No |
Tx/Rx Enable | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
VCC (max) | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
VCC (min) | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V |
VL Pin | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: ISL3159E (18)
- Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422
