Datasheet Intersil ISL32174E — Даташит
ПроизводительIntersil
СерияISL32174E
Quad, В±16.5kV ESD Protected, 3.0V to 5.5V, Low Power, RS-422 Transmitters
ISL32172E, ISL32272E, ISL32372E, ISL32174E, ISL32274E, ISL32374E, ISL32179E Datasheet
PDF, 1.4 Мб, Версия: 2017-10-10
49 предложений от 23 поставщиков
ISL32174EFVZ
Renesas
46 ₽
ISL32174EIBZ
Renesas
от 293 ₽
МосЧип
ISL32174E
Intersil
ISL32174EIBZ
Intersil
ISL32174EFBZISL32174EFBZ-TISL32174EFVZISL32174EFVZ-TISL32174EIBZISL32174EIBZ-TISL32174EIVZISL32174EIVZ-T
N12345678
Корпус16 Ld SOIC16 Ld SOIC T+R16 Ld TSSOP16 Ld TSSOP T+R16 Ld SOIC16 Ld SOIC T+R16 Ld TSSOP16 Ld TSSOP T+R
Parameters / ModelsISL32174EFBZISL32174EFBZ-TISL32174EFVZISL32174EFVZ-TISL32174EIBZISL32174EIBZ-TISL32174EIVZISL32174EIVZ-T
# of Tx44444444
Скорость передачи данных32 Mbps32 Mbps32 Mbps32 Mbps32 Mbps32 Mbps32 Mbps32 Mbps
DescriptionQuad, ?16.5kV ESD Protected, 3.0V to 5.5V, Low Power, RS-422 TransmittersQuad, ?16.5kV ESD Protected, 3.0V to 5.5V, Low Power, RS-422 TransmittersQuad, ?16.5kV ESD Protected, 3.0V to 5.5V, Low Power, RS-422 TransmittersQuad, ?16.5kV ESD Protected, 3.0V to 5.5V, Low Power, RS-422 TransmittersQuad, ?16.5kV ESD Protected, 3.0V to 5.5V, Low Power, RS-422 TransmittersQuad, ?16.5kV ESD Protected, 3.0V to 5.5V, Low Power, RS-422 TransmittersQuad, ?16.5kV ESD Protected, 3.0V to 5.5V, Low Power, RS-422 TransmittersQuad, ?16.5kV ESD Protected, 3.0V to 5.5V, Low Power, RS-422 Transmitters
Devices Allowed on Bus256256256256256256256256
Half/Full DuplexN/AN/AN/AN/AN/AN/AN/AN/A
High ESD?Yes-IEC61000Yes-IEC61000Yes-IEC61000Yes-IEC61000Yes-IEC61000Yes-IEC61000Yes-IEC61000Yes-IEC61000
Hot PlugYesYesYesYesYesYesYesYes
IS Enabled/Disabled600 μA600 μA600 μA600 μA600 μA600 μA600 μA600 μA
Key FeatureHigh SpeedHigh SpeedHigh SpeedHigh SpeedHigh SpeedHigh SpeedHigh SpeedHigh Speed
Рабочий диапазон температурот -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125
Peak Temp260°C260°C260°C260°C260°C260°C260°C260°C
Qualification LevelStandardStandardStandardStandardStandardStandardStandardStandard
SHDN ICCN/A μAN/A μAN/A μAN/A μAN/A μAN/A μAN/A μAN/A μA
Slew Rate LimitedNoNoNoNoNoNoNoNo
Tx/Rx EnableYes - Paired EnablesYes - Paired EnablesYes - Paired EnablesYes - Paired EnablesYes - Paired EnablesYes - Paired EnablesYes - Paired EnablesYes - Paired Enables
VCC (max)5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V
VCC (min)3 V3 V3 V3 V3 V3 V3 V3 V
VL PinNoNoNoNoNoNoNoNo
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
ISL32172E ISL32179E ISL32272E
  • Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422
На английском языке: Datasheet Intersil ISL32174E
