Datasheet Intersil ISL4485E — Даташит
Производитель | Intersil |
Серия | ISL4485E |
5V, Half Duplex, 20Mbps, В±15kV ESD Protected, RS-485/RS-422 Transceiver
![]() 42 предложений от 23 поставщиков Интегральные микросхемы Интерфейс - Драйверы, Приемники, Трансиверы | |||
ISL4485EIBZ-T Renesas | 53 ₽ | ||
ISL4485EIB-T Intersil | 67 ₽ | ||
ISL4485EIBZ-T Renesas | от 208 ₽ | ||
ISL4485EIB-T Intersil | по запросу |
ISL4485EIB | ISL4485EIB-T | ISL4485EIBZ | ISL4485EIBZ-T | |
N | 1 | 2 | 3 | 4 |
Корпус | 8 Ld SOIC | 8 Ld SOIC T+R | 8 Ld SOIC | 8 Ld SOIC T+R |
Parameters / Models | ISL4485EIB | ISL4485EIB-T | ISL4485EIBZ | ISL4485EIBZ-T |
# of Rx | 1 | 1 | 1 | 1 |
# of Tx | 1 | 1 | 1 | 1 |
Скорость передачи данных | 20 Mbps | 20 Mbps | 20 Mbps | 20 Mbps |
Description | 5V, Half Duplex, 20Mbps, ?15kV ESD Protected, RS-485/RS-422 Transceiver | 5V, Half Duplex, 20Mbps, ?15kV ESD Protected, RS-485/RS-422 Transceiver | 5V, Half Duplex, 20Mbps, ?15kV ESD Protected, RS-485/RS-422 Transceiver | 5V, Half Duplex, 20Mbps, ?15kV ESD Protected, RS-485/RS-422 Transceiver |
Devices Allowed on Bus | 32 | 32 | 32 | 32 |
Half/Full Duplex | Half | Half | Half | Half |
High ESD? | Yes | Yes | Yes | Yes |
Hot Plug | No | No | No | No |
IS Enabled/Disabled | 550/340 μA | 550/340 μA | 550/340 μA | 550/340 μA |
Key Feature | High Speed | High Speed | High Speed | High Speed |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Peak Temp | 240°C | 240°C | 260°C | 260°C |
Qualification Level | Standard | Standard | Standard | Standard |
SHDN ICC | N/A μA | N/A μA | N/A μA | N/A μA |
Slew Rate Limited | No | No | No | No |
Tx/Rx Enable | Yes | Yes | Yes | Yes |
VCC (max) | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
VCC (min) | 4.5 V | 4.5 V | 4.5 V | 4.5 V |
VL Pin | No | No | No | No |
Серия: ISL4485E (4)
- Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422
