Datasheet Intersil ISL8485E — Даташит
ПроизводительIntersil
СерияISL8485E
ESD Protected to В±15kV, 5V, Low Power, High SpeedRate Limited, RS-485/RS-422 Transceivers
ISL8483E, ISL8485E Datasheet
PDF, 1.2 Мб, Версия: 2017-08-31
81 предложений от 31 поставщиков
ISL8485IB
63 ₽
Эиком
ISL8485EIBZ
Renesas
от 121 ₽
ISL8485CPZ
Intersil
LifeElectronics
ISL8485IB-T
Intersil
ISL8485EABZISL8485EABZ-TISL8485ECBISL8485ECB-TISL8485ECBZISL8485ECBZ-TISL8485ECPISL8485ECPZISL8485EIBISL8485EIB-TISL8485EIBZISL8485EIBZ-TISL8485EIPISL8485EIPZISL8485EMPZ
N123456789101112131415
Корпус8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC8 Ld SOIC T+R8 Ld PDIP8 Ld PDIP8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC8 Ld SOIC T+R8 Ld PDIP8 Ld PDIP8 Ld PDIP
Parameters / ModelsISL8485EABZISL8485EABZ-TISL8485ECBISL8485ECB-TISL8485ECBZISL8485ECBZ-TISL8485ECPISL8485ECPZISL8485EIBISL8485EIB-TISL8485EIBZISL8485EIBZ-TISL8485EIPISL8485EIPZISL8485EMPZ
# of Rx111111111111111
# of Tx111111111111111
Скорость передачи данных10 Mbps10 Mbps10 Mbps10 Mbps10 Mbps10 Mbps10 Mbps10 Mbps10 Mbps10 Mbps10 Mbps10 Mbps10 Mbps10 Mbps10 Mbps
DescriptionESD Protected to ?15kV, 5V, Low Power, High SpeedRate Limited, RS-485/RS-422 TransceiversESD Protected to ?15kV, 5V, Low Power, High SpeedRate Limited, RS-485/RS-422 TransceiversESD Protected to ?15kV, 5V, Low Power, High SpeedRate Limited, RS-485/RS-422 TransceiversESD Protected to ?15kV, 5V, Low Power, High SpeedRate Limited, RS-485/RS-422 TransceiversESD Protected to ?15kV, 5V, Low Power, High SpeedRate Limited, RS-485/RS-422 TransceiversESD Protected to ?15kV, 5V, Low Power, High SpeedRate Limited, RS-485/RS-422 TransceiversESD Protected to ?15kV, 5V, Low Power, High SpeedRate Limited, RS-485/RS-422 TransceiversESD Protected to ?15kV, 5V, Low Power, High SpeedRate Limited, RS-485/RS-422 TransceiversESD Protected to ?15kV, 5V, Low Power, High SpeedRate Limited, RS-485/RS-422 TransceiversESD Protected to ?15kV, 5V, Low Power, High SpeedRate Limited, RS-485/RS-422 TransceiversESD Protected to ?15kV, 5V, Low Power, High SpeedRate Limited, RS-485/RS-422 TransceiversESD Protected to ?15kV, 5V, Low Power, High SpeedRate Limited, RS-485/RS-422 TransceiversESD Protected to ?15kV, 5V, Low Power, High SpeedRate Limited, RS-485/RS-422 TransceiversESD Protected to ?15kV, 5V, Low Power, High SpeedRate Limited, RS-485/RS-422 TransceiversESD Protected to ?15kV, 5V, Low Power, High SpeedRate Limited, RS-485/RS-422 Transceivers
Devices Allowed on Bus323232323232323232323232323232
Half/Full DuplexHalfHalfHalfHalfHalfHalfHalfHalfHalfHalfHalfHalfHalfHalfHalf
High ESD?YesYesYesYesYesYesYesYesYesYesYesYesYesYesYes
Hot PlugNoNoNoNoNoNoNoNoNoNoNoNoNoNoNo
IS Enabled/Disabled700/500 μA700/500 μA700/500 μA700/500 μA700/500 μA700/500 μA700/500 μA700/500 μA700/500 μA700/500 μA700/500 μA700/500 μA700/500 μA700/500 μA700/500 μA
Key FeatureLow CostLow CostLow CostLow CostLow CostLow CostLow CostLow CostLow CostLow CostLow CostLow CostLow CostLow CostLow Cost
Рабочий диапазон температурот -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125
Peak Temp260°C260°C240°C240°C260°C260°C240°C240°C260°C260°C
Qualification LevelStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandard
SHDN ICCN/A μAN/A μAN/A μAN/A μAN/A μAN/A μAN/A μAN/A μAN/A μAN/A μAN/A μAN/A μAN/A μAN/A μAN/A μA
Slew Rate LimitedNoNoNoNoNoNoNoNoNoNoNoNoNoNoNo
Tx/Rx EnableYesYesYesYesYesYesYesYesYesYesYesYesYesYesYes
VCC (max)5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V
VCC (min)4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V
VL PinNoNoNoNoNoNoNoNoNoNoNoNoNoNoNo
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
ISL8483E
  • Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422
На английском языке: Datasheet Intersil ISL8485E
