Datasheet Intersil ISL83086E — Даташит
Производитель | Intersil |
Серия | ISL83086E |
В±15kV ESD, 5V, Full Fail-Safe, 1/8 Unit Load, RS-485/RS-422 Transceivers
ISL83080E, ISL83082E, ISL83083E, ISL83084E, ISL83085E, ISL83086E, ISL83088E Datasheet
PDF, 1.2 Мб, Версия: 2017-10-20
![]() 48 предложений от 24 поставщиков +-15kV ESD Protected, 5V, Full Fail-Safe, Fractional (1/8) Unit Load, RS-485/RS-422 Transceivers | IC TXRX RS422/485 10MBPS 14SOICN | |||
ISL83086EIUZ-T Renesas | 36 ₽ | ||
ISL83086EIUZ-T Intersil | от 75 ₽ | ||
ISL83086EIUZ-T Renesas | по запросу | ||
ISL83086EIBZ-T Renesas | по запросу |
ISL83086EIB | ISL83086EIB-T | ISL83086EIBZ | ISL83086EIBZ-T | ISL83086EIUZ | ISL83086EIUZ-T | |
N | 1 | 2 | 3 | 4 | 5 | 6 |
Корпус | 14 Ld SOIC | 14 Ld SOIC T+R | 14 Ld SOIC | 14 Ld SOIC T+R | 10 Ld MSOP | 10 Ld MSOP T+R |
Parameters / Models | ISL83086EIB | ISL83086EIB-T | ISL83086EIBZ | ISL83086EIBZ-T | ISL83086EIUZ | ISL83086EIUZ-T |
# of Rx | 1 | 1 | 1 | 1 | 1 | 1 |
# of Tx | 1 | 1 | 1 | 1 | 1 | 1 |
Скорость передачи данных | 10 Mbps | 10 Mbps | 10 Mbps | 10 Mbps | 10 Mbps | 10 Mbps |
Description | ?15kV ESD, 5V, Full Fail-Safe, 1/8 Unit Load, RS-485/RS-422 Transceivers | ?15kV ESD, 5V, Full Fail-Safe, 1/8 Unit Load, RS-485/RS-422 Transceivers | ?15kV ESD, 5V, Full Fail-Safe, 1/8 Unit Load, RS-485/RS-422 Transceivers | ?15kV ESD, 5V, Full Fail-Safe, 1/8 Unit Load, RS-485/RS-422 Transceivers | ?15kV ESD, 5V, Full Fail-Safe, 1/8 Unit Load, RS-485/RS-422 Transceivers | ?15kV ESD, 5V, Full Fail-Safe, 1/8 Unit Load, RS-485/RS-422 Transceivers |
Devices Allowed on Bus | 256 | 256 | 256 | 256 | 256 | 256 |
Half/Full Duplex | Full | Full | Full | Full | Full | Full |
High ESD? | Yes | Yes | Yes | Yes | Yes | Yes |
Hot Plug | No | No | No | No | No | No |
IS Enabled/Disabled | 530/530 μA | 530/530 μA | 530/530 μA | 530/530 μA | 530/530 μA | 530/530 μA |
Key Feature | Low Cost | Low Cost | Low Cost | Low Cost | Low Cost | Low Cost |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Peak Temp | 240°C | 240°C | 260°C | 260°C | 260°C | 260°C |
Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard |
SHDN ICC | 0.07 μA | 0.07 μA | 0.07 μA | 0.07 μA | 0.07 μA | 0.07 μA |
Slew Rate Limited | No | No | No | No | No | No |
Tx/Rx Enable | Yes | Yes | Yes | Yes | Yes | Yes |
VCC (max) | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
VCC (min) | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V |
VL Pin | No | No | No | No | No | No |
RoHS | Совместим | Совместим | Совместим | Совместим |
ISL83080E ISL83082E ISL83083E ISL83085E ISL83088E
Серия: ISL83086E (6)
- Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422
