Datasheet Intersil ISL32275E — Даташит
| Производитель | Intersil |
| Серия | ISL32275E |
QUAD, В±16.5kV ESD Protected, 3.0V to 5.5V, RS-485/RS-422 Receivers
ISL32173E, ISL32273E, ISL32175E, ISL32275E, ISL32177E, ISL32277E Datasheet
PDF, 1.4 Мб, Версия: 2017-10-10
Купить ISL32275E на РадиоЛоцман.Цены — от 42 до 300 ₽23 предложений от 20 поставщиков QUAD, ?±16.5kV ESD Protected, 3.0V to 5.5V, RS-485/RS-422 Receivers | |||
| ISL32275EFVZ-T Intersil | 91 ₽ | ||
| ISL32275EFVZ Renesas | 224 ₽ | ||
| ISL32275EFVZ-T Intersil | по запросу | ||
| ISL32275EIBZ Intersil | по запросу | ||
| ISL32275EFBZ | ISL32275EFBZ-T | ISL32275EFVZ | ISL32275EFVZ-T | ISL32275EIBZ | ISL32275EIBZ-T | ISL32275EIVZ | ISL32275EIVZ-T | |
| N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 |
| Корпус | 16 Ld SOIC | 16 Ld SOIC T+R | 16 Ld TSSOP | 16 Ld TSSOP T+R | 16 Ld SOIC | 16 Ld SOIC T+R | 16 Ld TSSOP | 16 Ld TSSOP T+R |
| Parameters / Models | ISL32275EFBZ | ISL32275EFBZ-T | ISL32275EFVZ | ISL32275EFVZ-T | ISL32275EIBZ | ISL32275EIBZ-T | ISL32275EIVZ | ISL32275EIVZ-T |
| # of Rx | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 |
| Скорость передачи данных | 20 Mbps | 20 Mbps | 20 Mbps | 20 Mbps | 20 Mbps | 20 Mbps | 20 Mbps | 20 Mbps |
| Description | QUAD, ?16.5kV ESD Protected, 3.0V to 5.5V, RS-485/RS-422 Receivers | QUAD, ?16.5kV ESD Protected, 3.0V to 5.5V, RS-485/RS-422 Receivers | QUAD, ?16.5kV ESD Protected, 3.0V to 5.5V, RS-485/RS-422 Receivers | QUAD, ?16.5kV ESD Protected, 3.0V to 5.5V, RS-485/RS-422 Receivers | QUAD, ?16.5kV ESD Protected, 3.0V to 5.5V, RS-485/RS-422 Receivers | QUAD, ?16.5kV ESD Protected, 3.0V to 5.5V, RS-485/RS-422 Receivers | QUAD, ?16.5kV ESD Protected, 3.0V to 5.5V, RS-485/RS-422 Receivers | QUAD, ?16.5kV ESD Protected, 3.0V to 5.5V, RS-485/RS-422 Receivers |
| Devices Allowed on Bus | 128 | 128 | 128 | 128 | 128 | 128 | 128 | 128 |
| Half/Full Duplex | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A |
| High ESD? | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 |
| Hot Plug | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
| IS Enabled/Disabled | 5500 μA | 5500 μA | 5500 μA | 5500 μA | 5500 μA | 5500 μA | 5500 μA | 5500 μA |
| Key Feature | High Speed | High Speed | High Speed | High Speed | High Speed | High Speed | High Speed | High Speed |
| Рабочий диапазон температур | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 |
| Peak Temp | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C |
| Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
| SHDN ICC | 60 μA | 60 μA | 60 μA | 60 μA | 60 μA | 60 μA | 60 μA | 60 μA |
| Slew Rate Limited | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A |
| Tx/Rx Enable | Yes - Paired Enables | Yes - Paired Enables | Yes - Paired Enables | Yes - Paired Enables | Yes - Paired Enables | Yes - Paired Enables | Yes - Paired Enables | Yes - Paired Enables |
| VCC (max) | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
| VCC (min) | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V |
| VL Pin | No | No | No | No | No | No | No | No |
| RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
ISL32173E ISL32177E ISL32273E ISL32277E
Серия: ISL32275E (8)
- Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422
