Datasheet Intersil ISL3158E — Даташит
| Производитель | Intersil |
| Серия | ISL3158E |
5 В, полный отказоустойчивый приемопередатчик RS-485/RS-422 с защитой от электростатического разряда
ISL3150E, ISL3152E, ISL3153E, ISL3155E, ISL3156E, ISL3158E Datasheet
PDF, 1.7 Мб, Версия: 2017-08-31
Купить ISL3158E на РадиоЛоцман.Цены — от 30 до 218 ₽48 предложений от 22 поставщиков ?±16.5kV ESD (IEC61000-4-2) Protected, Large Output Swing, 5V, Full Fail-Safe, 1/8 Unit Load, RS-485/RS-422 Transceiver | |||
| ISL3158EIUZ-T Renesas | от 30 ₽ | ||
| ISL3158EIUZ-T-TUDI | 54 ₽ | ||
| ISL3158EIBZ-T Renesas | от 185 ₽ | ||
| ISL3158EIUZ-T Intersil | по запросу | ||
| ISL3158EIBZ | ISL3158EIBZ-T | ISL3158EIBZ-T7A | ISL3158EIUZ | ISL3158EIUZ-T | ISL3158EIUZ-T7A | |
| N | 1 | 2 | 3 | 4 | 5 | 6 |
| Корпус | 8 Ld SOIC | 8 Ld SOIC T+R | 8 Ld SOIC T+R | 8 Ld MSOP | 8 Ld MSOP T+R | 8 Ld MSOP T+R |
| Parameters / Models | ISL3158EIBZ | ISL3158EIBZ-T | ISL3158EIBZ-T7A | ISL3158EIUZ | ISL3158EIUZ-T | ISL3158EIUZ-T7A |
| # of Rx | 1 | 1 | 1 | 1 | 1 | 1 |
| # of Tx | 1 | 1 | 1 | 1 | 1 | 1 |
| Скорость передачи данных | 20 Mbps | 20 Mbps | 20 Mbps | 20 Mbps | 20 Mbps | 20 Mbps |
| Description | 5V, Full Fail-safe, RS-485/RS-422 Transceiver with ESD Protection | 5V, Full Fail-safe, RS-485/RS-422 Transceiver with ESD Protection | 5V, Full Fail-safe, RS-485/RS-422 Transceiver with ESD Protection | 5V, Full Fail-safe, RS-485/RS-422 Transceiver with ESD Protection | 5V, Full Fail-safe, RS-485/RS-422 Transceiver with ESD Protection | 5V, Full Fail-safe, RS-485/RS-422 Transceiver with ESD Protection |
| Devices Allowed on Bus | 256 | 256 | 256 | 256 | 256 | 256 |
| Half/Full Duplex | Half | Half | Half | Half | Half | Half |
| High ESD? | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 |
| Hot Plug | Yes | Yes | Yes | Yes | Yes | Yes |
| IS Enabled/Disabled | 800/700 μA | 800/700 μA | 800/700 μA | 800/700 μA | 800/700 μA | 800/700 μA |
| Key Feature | High Speed | High Speed | High Speed | High Speed | High Speed | High Speed |
| Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
| Peak Temp | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C |
| Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard |
| SHDN ICC | 0.07 μA | 0.07 μA | 0.07 μA | 0.07 μA | 0.07 μA | 0.07 μA |
| Slew Rate Limited | No | No | No | No | No | No |
| Tx/Rx Enable | Yes | Yes | Yes | Yes | Yes | Yes |
| VCC (max) | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
| VCC (min) | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V |
| VL Pin | No | No | No | No | No | No |
| RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
ISL3150E ISL3152E ISL3153E ISL3155E ISL3156E
Серия: ISL3158E (6)
- Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422
