Datasheet Intersil ISL3171E — Даташит
Производитель | Intersil |
Серия | ISL3171E |
В±15kV ESD Protected, 3.3V, Full-duplex, 250kbps RS-485/RS-422 Transceiver
![]() 55 предложений от 22 поставщиков Интегральные микросхемы Интерфейс - Драйверы, Приемники, Трансиверы | |||
ISL3171EIUZ Renesas | от 31 ₽ | ||
ISL3171EIBZ Renesas | 131 ₽ | ||
ISL3171EIBZ-T Intersil | по запросу | ||
ISL3171E Intersil | по запросу |
ISL3171EIBZ | ISL3171EIBZ-T | ISL3171EIBZ-T7A | ISL3171EIUZ | ISL3171EIUZ-T | |
N | 1 | 2 | 3 | 4 | 5 |
Корпус | 8 Ld SOIC | 8 Ld SOIC T+R | 8 Ld SOIC T+R | 8 Ld MSOP | 8 Ld MSOP T+R |
Parameters / Models | ISL3171EIBZ | ISL3171EIBZ-T | ISL3171EIBZ-T7A | ISL3171EIUZ | ISL3171EIUZ-T |
# of Rx | 1 | 1 | 1 | 1 | 1 |
# of Tx | 1 | 1 | 1 | 1 | 1 |
Скорость передачи данных | 0.25 Mbps | 0.25 Mbps | 0.25 Mbps | 0.25 Mbps | 0.25 Mbps |
Description | ?15kV ESD Protected, 3.3V, Full-duplex, 250kbps RS-485/RS-422 Transceiver | ?15kV ESD Protected, 3.3V, Full-duplex, 250kbps RS-485/RS-422 Transceiver | ?15kV ESD Protected, 3.3V, Full-duplex, 250kbps RS-485/RS-422 Transceiver | ?15kV ESD Protected, 3.3V, Full-duplex, 250kbps RS-485/RS-422 Transceiver | ?15kV ESD Protected, 3.3V, Full-duplex, 250kbps RS-485/RS-422 Transceiver |
Devices Allowed on Bus | 256 | 256 | 256 | 256 | 256 |
Half/Full Duplex | Full | Full | Full | Full | Full |
High ESD? | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 |
Hot Plug | No | No | No | No | No |
IS Enabled/Disabled | 510 μA | 510 μA | 510 μA | 510 μA | 510 μA |
Key Feature | Ruggedized | Ruggedized | Ruggedized | Ruggedized | Ruggedized |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Peak Temp | 260°C | 260°C | 260°C | 260°C | 260°C |
Qualification Level | Standard | Standard | Standard | Standard | Standard |
SHDN ICC | N/A μA | N/A μA | N/A μA | N/A μA | N/A μA |
Slew Rate Limited | Yes | Yes | Yes | Yes | Yes |
Tx/Rx Enable | No | No | No | No | No |
VCC (max) | 3.6 V | 3.6 V | 3.6 V | 3.6 V | 3.6 V |
VCC (min) | 3 V | 3 V | 3 V | 3 V | 3 V |
VL Pin | No | No | No | No | No |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим |
ISL3170E ISL3172E ISL3173E ISL3174E ISL3175E ISL3176E ISL3177E ISL3178E
Серия: ISL3171E (5)
- Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422
