Datasheet Intersil ISL3175E — Даташит
Производитель | Intersil |
Серия | ISL3175E |
В±15kV IEC ESD Protected, 3.3V, Half-duplex, 500kbps RS-485/RS-422 Transceiver with Tx/Rx enable
![]() 46 предложений от 21 поставщиков Интегральные микросхемы Интерфейс - Драйверы, Приемники, Трансиверы | |||
ISL3175EIBZ-T Intersil | 48 ₽ | ||
ISL3175EIBZ Renesas | от 73 ₽ | ||
ISL3175EIUZ-T Renesas | от 228 ₽ | ||
ISL3175EIBZ-T Intersil | по запросу |
ISL3175EIBZ | ISL3175EIBZ-T | ISL3175EIUZ | ISL3175EIUZ-T | |
N | 1 | 2 | 3 | 4 |
Корпус | 8 Ld SOIC | 8 Ld SOIC T+R | 8 Ld MSOP | 8 Ld MSOP T+R |
Parameters / Models | ISL3175EIBZ | ISL3175EIBZ-T | ISL3175EIUZ | ISL3175EIUZ-T |
# of Rx | 1 | 1 | 1 | 1 |
# of Tx | 1 | 1 | 1 | 1 |
Скорость передачи данных | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps | 0.5 Mbps |
Description | ?15kV IEC ESD Protected, 3.3V, Half-duplex, 500kbps RS-485/RS-422 Transceiver with Tx/Rx enable | ?15kV IEC ESD Protected, 3.3V, Half-duplex, 500kbps RS-485/RS-422 Transceiver with Tx/Rx enable | ?15kV IEC ESD Protected, 3.3V, Half-duplex, 500kbps RS-485/RS-422 Transceiver with Tx/Rx enable | ?15kV IEC ESD Protected, 3.3V, Half-duplex, 500kbps RS-485/RS-422 Transceiver with Tx/Rx enable |
Devices Allowed on Bus | 256 | 256 | 256 | 256 |
Half/Full Duplex | Half | Half | Half | Half |
High ESD? | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 | Yes-IEC61000 |
Hot Plug | Yes | Yes | Yes | Yes |
IS Enabled/Disabled | 510/480 μA | 510/480 μA | 510/480 μA | 510/480 μA |
Key Feature | Ruggedized | Ruggedized | Ruggedized | Ruggedized |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Peak Temp | 260°C | 260°C | 260°C | 260°C |
Qualification Level | Standard | Standard | Standard | Standard |
SHDN ICC | 0.01 μA | 0.01 μA | 0.01 μA | 0.01 μA |
Slew Rate Limited | Yes | Yes | Yes | Yes |
Tx/Rx Enable | Yes | Yes | Yes | Yes |
VCC (max) | 3.6 V | 3.6 V | 3.6 V | 3.6 V |
VCC (min) | 3 V | 3 V | 3 V | 3 V |
VL Pin | No | No | No | No |
RoHS | Совместим | Совместим | Совместим | Совместим |
ISL3170E ISL3171E ISL3172E ISL3173E ISL3174E ISL3176E ISL3177E ISL3178E
Серия: ISL3175E (4)
- Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422
