Datasheet Intersil ISL32612EFHZ-T7A — Даташит
Производитель | Intersil |
Серия | ISL32612E |
Модель | ISL32612EFHZ-T7A |
В±16.5kV IEC ESD, 1.8V, Micro Power, RS-485/RS-422 Differential Receiver with active high Rx enable
![]() 28 предложений от 13 поставщиков Чип интерфейса, 16.5kV ESD Protected, 1.8V, Micro Power, 125℃, 1/8 Unit Load, RS-485/RS-422 Differential Receivers | |||
ISL32612EFHZ-T7A Intersil | 79 ₽ | ||
ISL32612EFHZ-T7A Intersil | от 422 ₽ | ||
ISL32612EFHZ-T7A Renesas | от 457 ₽ | ||
ISL32612EFHZ-T7A Renesas | по запросу |
Корпус | 6 Ld SOT T+R |
# of Rx | 1 |
Скорость передачи данных | 0.256 Mbps |
Description | ?16.5kV IEC ESD, 1.8V, Micro Power, RS-485/RS-422 Differential Receiver with active high Rx enable |
Devices Allowed on Bus | 256 |
Half/Full Duplex | N/A |
High ESD? | Yes-IEC61000 |
Hot Plug | No |
IS Enabled/Disabled | 85 μA |
Key Feature | Low Power |
Рабочий диапазон температур | от -40 до 125 |
Peak Temp | 260°C |
SHDN ICC | .007 μA |
Slew Rate Limited | N/A |
Tx/Rx Enable | Yes - Active High |
VCC (max) | 3.6 V |
VCC (min) | 1.8 V |
VL Pin | No |
Серия: ISL32612E (2)
- ISL32612EFHZ-T ISL32612EFHZ-T7A
- Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422
ISL32612EFHZT7A, ISL32612EFHZ T7A
