Datasheet Intersil ISL32437E — Даташит
| Производитель | Intersil |
| Серия | ISL32437E |
В±40V Fault Protected, 3.3V to 5V, В±15V CMR, RS-485/RS-422 With Cable Invert and В±15kV ESD
ISL32430E, ISL32432E, ISL32433E, ISL32435E, ISL32437E Datasheet
PDF, 1.2 Мб, Версия: 2017-10-10
|  Купить ISL32437E на РадиоЛоцман.Цены — от 101 до 771 ₽ 27 предложений от 17 поставщиков , ±40V Fault Protected, 3.3V to 5V, ±15V Common Mode Range, RS-485/RS-422 Transceivers With Cable Invert and ±15kV ESD | |||
| ISL32437EIBZ Renesas | 771 ₽ | ||
| ISL32437EIUZ Intersil | по запросу | ||
| ISL32437EIUZ-T Intersil | по запросу | ||
| ISL32437EIBZ Intersil | по запросу | ||
| ISL32437EIBZ | ISL32437EIBZ-T | ISL32437EIBZ-T7A | ISL32437EIUZ | ISL32437EIUZ-T | ISL32437EIUZ-T7A | |
| N | 1 | 2 | 3 | 4 | 5 | 6 |
| Корпус | 8 Ld SOIC | 8 Ld SOIC T+R | 8 Ld SOIC T+R | 8 Ld MSOP | 8 Ld MSOP T+R | 8 Ld MSOP T+R |
| Parameters / Models | ISL32437EIBZ | ISL32437EIBZ-T | ISL32437EIBZ-T7A | ISL32437EIUZ | ISL32437EIUZ-T | ISL32437EIUZ-T7A |
| # of Rx | 1 | 1 | 1 | 1 | 1 | 1 |
| # of Tx | 1 | 1 | 1 | 1 | 1 | 1 |
| Common Mode Voltage Range | В±15 V | В±15 V | В±15 V | В±15 V | В±15 V | В±15 V |
| Скорость передачи данных | .25 Mbps | .25 Mbps | .25 Mbps | .25 Mbps | .25 Mbps | .25 Mbps |
| Description | ?40V Fault Protected, 3.3V to 5V, ?15V CMR, RS-485/RS-422 With Cable Invert and ?15kV ESD | ?40V Fault Protected, 3.3V to 5V, ?15V CMR, RS-485/RS-422 With Cable Invert and ?15kV ESD | ?40V Fault Protected, 3.3V to 5V, ?15V CMR, RS-485/RS-422 With Cable Invert and ?15kV ESD | ?40V Fault Protected, 3.3V to 5V, ?15V CMR, RS-485/RS-422 With Cable Invert and ?15kV ESD | ?40V Fault Protected, 3.3V to 5V, ?15V CMR, RS-485/RS-422 With Cable Invert and ?15kV ESD | ?40V Fault Protected, 3.3V to 5V, ?15V CMR, RS-485/RS-422 With Cable Invert and ?15kV ESD |
| Devices Allowed on Bus | 128 | 128 | 128 | 128 | 128 | 128 |
| Fault Voltage Level | В±40 V | В±40 V | В±40 V | В±40 V | В±40 V | В±40 V |
| Half/Full Duplex | Half | Half | Half | Half | Half | Half |
| High ESD? | Yes | Yes | Yes | Yes | Yes | Yes |
| Hot Plug | No | No | No | No | No | No |
| ICC | 2.1 mA | 2.1 mA | 2.1 mA | 2.1 mA | 2.1 mA | 2.1 mA |
| Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
| Peak Temp | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C |
| Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard |
| SHDN ICC | 10 μA | 10 μA | 10 μA | 10 μA | 10 μA | 10 μA |
| Slew Rate Limited | Yes | Yes | Yes | Yes | Yes | Yes |
| Tx/Rx Enable | Tx Only | Tx Only | Tx Only | Tx Only | Tx Only | Tx Only |
| VCC (min) | 3.3 V | 3.3 V | 3.3 V | 3.3 V | 3.3 V | 3.3 V |
| VL Pin | No | No | No | No | No | No |
| RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
ISL32430E ISL32432E ISL32433E ISL32435E
Серия: ISL32437E (6)
- Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422 Fault Protected
