Datasheet Intersil ISL32457E — Даташит
| Производитель | Intersil |
| Серия | ISL32457E |
В±60V Fault Protected, 3.3V to 5V, В±20V CMR, RS-485/RS-422 With Cable Invert and В±15kV ESD
ISL32450E, ISL32452E, ISL32453E, ISL32455E, ISL32457E, ISL32458E, ISL32459E Datasheet
PDF, 1.6 Мб, Версия: 2017-08-31
Купить ISL32457E на РадиоЛоцман.Цены — от 98 до 808 ₽23 предложений от 16 поставщиков Интегральные микросхемы Интерфейс - Драйверы, Приемники, Трансиверы | |||
| ISL32457EIBZ-T Intersil | 198 ₽ | ||
| ISL32457EIUZ-T Intersil | 249 ₽ | ||
| ISL32457EIBZ-T Intersil | по запросу | ||
| ISL32457EIUZ-T Renesas | по запросу | ||
| ISL32457EIBZ | ISL32457EIBZ-T | ISL32457EIBZ-T7A | ISL32457EIUZ | ISL32457EIUZ-T | ISL32457EIUZ-T7A | |
| N | 1 | 2 | 3 | 4 | 5 | 6 |
| Корпус | 8 Ld SOIC | 8 Ld SOIC T+R | 8 Ld SOIC T+R | 8 Ld MSOP | 8 Ld MSOP T+R | 8 Ld MSOP T+R |
| Parameters / Models | ISL32457EIBZ | ISL32457EIBZ-T | ISL32457EIBZ-T7A | ISL32457EIUZ | ISL32457EIUZ-T | ISL32457EIUZ-T7A |
| # of Rx | 1 | 1 | 1 | 1 | 1 | 1 |
| # of Tx | 1 | 1 | 1 | 1 | 1 | 1 |
| Common Mode Voltage Range | В±20 V | В±20 V | В±20 V | В±20 V | В±20 V | В±20 V |
| Скорость передачи данных | .25 Mbps | .25 Mbps | .25 Mbps | .25 Mbps | .25 Mbps | .25 Mbps |
| Description | ?60V Fault Protected, 3.3V to 5V, ?20V CMR, RS-485/RS-422 With Cable Invert and ?15kV ESD | ?60V Fault Protected, 3.3V to 5V, ?20V CMR, RS-485/RS-422 With Cable Invert and ?15kV ESD | ?60V Fault Protected, 3.3V to 5V, ?20V CMR, RS-485/RS-422 With Cable Invert and ?15kV ESD | ?60V Fault Protected, 3.3V to 5V, ?20V CMR, RS-485/RS-422 With Cable Invert and ?15kV ESD | ?60V Fault Protected, 3.3V to 5V, ?20V CMR, RS-485/RS-422 With Cable Invert and ?15kV ESD | ?60V Fault Protected, 3.3V to 5V, ?20V CMR, RS-485/RS-422 With Cable Invert and ?15kV ESD |
| Devices Allowed on Bus | 128 | 128 | 128 | 128 | 128 | 128 |
| Fault Voltage Level | В±60 V | В±60 V | В±60 V | В±60 V | В±60 V | В±60 V |
| Half/Full Duplex | Half | Half | Half | Half | Half | Half |
| High ESD? | Yes | Yes | Yes | Yes | Yes | Yes |
| Hot Plug | No | No | No | No | No | No |
| ICC | 2.1 mA | 2.1 mA | 2.1 mA | 2.1 mA | 2.1 mA | 2.1 mA |
| Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
| Peak Temp | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C |
| Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard |
| SHDN ICC | 10 μA | 10 μA | 10 μA | 10 μA | 10 μA | 10 μA |
| Slew Rate Limited | Yes | Yes | Yes | Yes | Yes | Yes |
| Tx/Rx Enable | Tx Only | Tx Only | Tx Only | Tx Only | Tx Only | Tx Only |
| VCC (min) | 3.0 V | 3.0 V | 3.0 V | 3.0 V | 3.0 V | 3.0 V |
| VL Pin | No | No | No | No | No | No |
| RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
ISL32450E ISL32452E ISL32453E ISL32455E ISL32458E ISL32459E
Серия: ISL32457E (6)
- Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422 Fault Protected
