Datasheet Intersil ISL31491E — Даташит
ПроизводительIntersil
СерияISL31491E
В±60V Fault Protected, 5V, RS-485/RS-422 Transceivers with В±25V Common Mode Range
ISL31490E, ISL31491E, ISL31492E, ISL31493E, ISL31495E, ISL31496E, ISL31498E Datasheet
PDF, 1.5 Мб, Версия: 2017-11-13
35 предложений от 19 поставщиков
ISL31491EIBZ
Renesas
60 ₽
ISL31491EIBZ
Renesas
293 ₽
ISL31491EIBZ
Renesas
от 393 ₽
Hi-Tech Circuit Group
ISL31491EIBZ-T
ISL31491EIBZISL31491EIBZ-TISL31491EIBZ-T7A
N123
Корпус8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC T+R
Parameters / ModelsISL31491EIBZISL31491EIBZ-TISL31491EIBZ-T7A
# of Rx111
# of Tx111
Common Mode Voltage RangeВ±25 VВ±25 VВ±25 V
Скорость передачи данных0.25 Mbps0.25 Mbps0.25 Mbps
Description?60V Fault Protected, 5V, RS-485/RS-422 Transceivers with ?25V Common Mode Range?60V Fault Protected, 5V, RS-485/RS-422 Transceivers with ?25V Common Mode Range?60V Fault Protected, 5V, RS-485/RS-422 Transceivers with ?25V Common Mode Range
Devices Allowed on Bus128128128
Fault Voltage LevelВ±60 VВ±60 VВ±60 V
Half/Full DuplexFullFullFull
High ESD?NoNoNo
Hot PlugYesYesYes
ICC2.3 mA2.3 mA2.3 mA
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85
Peak Temp260°C260°C260°C
Qualification LevelStandardStandardStandard
SHDN ICCN/A μAN/A μAN/A μA
Slew Rate LimitedYesYesYes
Tx/Rx EnableNoNoNo
VCC (min)4.5 V4.5 V4.5 V
VL PinNoNoNo
ISL31490E ISL31492E ISL31495E ISL31496E ISL31498E
  • Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422 Fault Protected
На английском языке: Datasheet Intersil ISL31491E
